Headlight Warning Chime (1990)?
Old May 1, 2015 | 09:02 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Headlight Warning Chime (1990)?
Where is it? Mine does not seem to want to work.. I would like to fix that at least so I don't accidentally kill my battery..
IS it a separate module? I don't have my FSM with me
Old May 1, 2015 | 09:16 AM
WVZR-1's Avatar
WVZR-1
It's behind the DIC in the same place as the LTPWS module that you asked about earlier. You could maybe have it "turned off" in the CCM maybe. I believe it can be but I don't believe but's a documented DIY thing.
Is it just the HL chime or you have "NO CHIMES" at all?
Old May 1, 2015 | 09:18 AM
-=Jeff=-'s Avatar
-=Jeff=-
It will Chime as it see fit.. so once in a while it works most times it does not work
So it could be a intermittent module or wiring leading to it.. I am thinking it is the audio chime itself, as when it does work the chime sounds a bit 'sick' at first
To Headlight Warning Chime (1990)?
