Noisy front shocks
Old Aug 14, 2002 | 01:56 PM
Kevin McGrade's Avatar
Kevin McGrade
Default Noisy front shocks
How and with what do I lube or grease my front shocks. They are the FX3 bilsteins.
They are squeeking a bit when i go over the speed bumps at home
Old Aug 14, 2002 | 02:09 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Noisy front shocks (Kevin McGrade)
You might need to replace them...miles?
Old Aug 14, 2002 | 02:11 PM
Kevin McGrade
Default Re: Noisy front shocks (Zora)
They have less than 20k on them :confused:
Old Aug 15, 2002 | 02:58 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
squeeking shocks? :confused:
sure it's not the bushings?
Old Aug 15, 2002 | 03:15 PM
Raysur's Avatar
Raysur
Default Re: Noisy front shocks (BrianCunningham)
Go to a lube shop and have them grease your front end. You should do this every other oil change.:yesnod:
Shocks shouldn't make noises. :confused:
Old Aug 15, 2002 | 03:30 PM
chilihed'95coupe's Avatar
chilihed'95coupe
Default Re: Noisy front shocks (Raysur)
Old Aug 15, 2002 | 07:35 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Noisy front shocks (chilihed'95coupe)
I would think its not the shocks. Its likely the front spring or spring mounts. Many vettes do it I had to do mine on the 84. If you figured out that it is the shocks you can delete the FX3 but i would just fix it. :smash:
To Noisy front shocks
