please help.!
Old May 1, 2015 | 04:56 PM
jpeters11's Avatar
jpeters11
Default please help.!
84 vette. Went to go start it one morning and it did Not want to stay running.. runs like it's missing, but just put new plugs and wires on it Not To Long ago. Basically it will want to die when givin throttle, like it's starving for fuel. Any suggestions thanks.!
Old May 1, 2015 | 05:07 PM
antfarmer2's Avatar
antfarmer2
Check your fuel pressure..............filter and pump
Old May 1, 2015 | 05:14 PM
don hall's Avatar
don hall
Your vette may tell you the problem:
http://www.corvettephotographs.com/c4vettes/ecm.htm
Old May 1, 2015 | 08:07 PM
jpeters11's Avatar
jpeters11
Filter is good.. how do you check the pressure and pump?
Old May 1, 2015 | 10:09 PM
antfarmer2's Avatar
antfarmer2
Put a pressure gauge on it
Old May 1, 2015 | 10:18 PM
Hot Rod Roy's Avatar
Hot Rod Roy
AntFarmer, if you had an '84, how would you put a pressure gauge on it?
Old May 2, 2015 | 09:00 AM
jpeters11's Avatar
jpeters11
I'm guessing attache a pressure tester on the end of the fuel line?
Old May 2, 2015 | 09:13 AM
antfarmer2's Avatar
antfarmer2
Sounds like a plan to me but look for a shrader valve my 94 has one not sure about the 84 or maybe right after the pump
Old May 2, 2015 | 09:26 AM
active1951's Avatar
active1951
Default 84 fuel pressure
maybe this way?
Old May 2, 2015 | 01:06 PM
Hot Rod Roy
Absolutely amazing suggestions! Is there anybody out there that knows what they're talking about???
Old May 2, 2015 | 02:49 PM
antfarmer2's Avatar
antfarmer2
Mabye not I have a 94. But trying to help and sure he could use your expert help instead of your lip
Old May 2, 2015 | 03:56 PM
active1951's Avatar
active1951
I heard dat, antfarmer.
I have a 94 too. Maybe 94 owners like helpin folks.
I was born/raised in Texas, is it gettin hot there yet?
Old May 2, 2015 | 04:36 PM
jpeters11's Avatar
jpeters11
Sounds like it might be a pump or something inside the tank, not getting fuel anymore. Anybody pull a tank on a c4 before?
Old May 3, 2015 | 10:56 AM
antfarmer2's Avatar
antfarmer2
Not sure on your but think it is the same don't pull the tank!!!!!! Just take the the fuel door off then the plastic cover undo the hoses a few bolts and it comes out the top easyest fuel pump change ever
Old May 3, 2015 | 10:59 AM
antfarmer2's Avatar
antfarmer2
not yet but you know it's coming
Old May 4, 2015 | 09:52 PM
jpeters11's Avatar
jpeters11
Yeah figured it out. Pulled the sending unit out and the main fuel line from the pump came off, while I had it out went ahead and put a new pump and strainer in it. Figured I should since it was 30 years old. Thanks for the advice guys.!
Old May 4, 2015 | 09:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
like it's starving for fuel. Any suggestions?
Yes. Check your fuel pressure.
Old May 4, 2015 | 09:55 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
There you go.
Old May 4, 2015 | 10:18 PM
antfarmer2's Avatar
antfarmer2
good job
To please help.!
