Vacuum line picture
Old May 2, 2015 | 01:54 PM
mlm0's Avatar
mlm0
Default Vacuum line picture
89 auto. If someone gets a chance, I could sure use a picture of where the vacuum line plugs into the TB on the passenger side. Mine broke off and I am trying to fix it back like factory. I made a rubber connection but I don't like the way it looks
Thanks in advance for taking the time and trouble
Old May 2, 2015 | 02:37 PM
WW7's Avatar
WW7
Here's a diagram.The tube that goes under the TB then connects on the passenger side was made of plastic tube with a rubber fitting on it to attach to the TB.The plastic tube was about 10 inchs long, then it connected to a rubber tube that went to the "purge cont solenoid" thats in the picture below...WW
Old May 2, 2015 | 03:59 PM
mlm0's Avatar
mlm0
Thanks. I have a diagram. Need to see what kind of connection at TB, but I do have question. I can't seem to locate the line that connects the fuel pressure to the air cap
Old May 3, 2015 | 01:11 AM
Cliff Harris's Avatar
Cliff Harris
Use this picture to identify the part you need and we can go from there:
Old May 3, 2015 | 08:49 AM
WW7's Avatar
WW7
Your lucky, I just happened to have my motor torn apart and could get a picture of the tube that goes to the TB..It's number #27 in Cliffs schematic above........WW
Old May 3, 2015 | 09:34 AM
mlm0's Avatar
mlm0
Perfect. Thanks so very much. I owe you one
Mike
To Vacuum line picture
