LT1 PCV system
Old May 5, 2015 | 07:48 PM
Impala Balko's Avatar
Impala Balko
Default LT1 PCV system
I have a 94 6 speed with a remote mount turbo setup with 10 lbs of boost and i am noticing that when I come off boost I am getting a little bit of blow by and it seems like some oil is coming out of the dipstick. I have a stock PCV valve and i have tried a one way check valve however the check valve just seemed to make things worse. What should I do to fix this?
Old May 6, 2015 | 06:02 AM
gerardvg's Avatar
gerardvg
Hi
You need to block the pcv hose, remove the dipstick and cap it.
I have a custom valve cover cap with a hose to an oil catch can.
Any vacuum port can be influenced by the blowby and pressurizes the crankcase forcing oil out the dipstick and seals.
Cheers
Old May 6, 2015 | 06:27 AM
Impala Balko
Originally Posted by gerardvg
Hi
Cheers
I am having trouble envisioning this do you have any pictures of a catch can setup
Old May 6, 2015 | 06:12 PM
dizwiz24's Avatar
dizwiz24
Are you saying you disabled the pcv and blocked off the oil dipstick tube, making the valve cover breathrs the only orifice oil can come out of ...at which point it goes into a catch can.....
Old May 7, 2015 | 04:51 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
How are you brakes hooked up?
Old May 7, 2015 | 06:58 PM
Impala Balko
Just the way the way they came from the factory vacuum
Old May 9, 2015 | 09:38 AM
Impala Balko
Do I have to modify how the brakes are setup with the vacuum assist
Old May 11, 2015 | 03:13 PM
BrianCunningham
Yes, it needs a check valve so the brake booster doesn't see, well boost.
Otherwise your vacuum assist will turn into boost detriment
Old May 11, 2015 | 03:42 PM
Impala Balko
Do you have any detailed pics of your PCV and brake setup
Old May 12, 2015 | 01:29 PM
BrianCunningham
no, I need to take some
Old May 12, 2015 | 02:46 PM
Impala Balko
Can you grab some pics for me please I need to get this sorted out
Old Jun 17, 2015 | 11:05 PM
Scootin_Z's Avatar
Scootin_Z
I would be interested in seeing these pictures as well. I was pushing oil out the front seals with my oil cap on and just for a temporary setup I put a filler neck from a Tahoe on my valve cover fill and zip tied a rag to the neck of it so it can relieve the pressure.looks pretty hokey but it works for now.
Old Jun 18, 2015 | 11:08 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
OK some practical history here. First the checkvalve on the brake booster is a checkvalve. If it fails you may damage your booster but it is rare. However all my kits include a checkvale to insert in-line because a checkvalve is a hell of a lot less money than a new booster !!!!
Next - do you need a PCV valve. No not really but it is a GOOD thing to have as it cleans your crankcase during normal driving. Most PCV valves will leak a little boost to crankcase under boosted conditions so good to add an in-line checkvalve to the PCV system if one is to keep. A decent checkvalve may cost you $15. On the LTx difficult to add because of the little 'U' tube hose but can be done. I made an integral PCV and check but too expensive.
Crankcase Breathing: First if you blow out the dipstick buy a new one. The rubber seal goes bad. If you blow out the new dipstick you have a serious blow-by issue (assuming open breathers on each valve cover) !!!!!!!!!!! And with that I recommend open breathers on each valve cover. If emissions inspection require closed loop then get breathers with hose connections and connect to air filter.
So after all of the above you are still dripping oil: THEN get a new and professional engine builder ! A properly built SBC engine under 15 pounds of boost will not blow oil out breathers and require an exotic catch-can system !!!!!!!!
But if you must blow oil then by all means build your self a really good catch can system !!!!!!!!!!!! LOL
greg
Old Jun 18, 2015 | 09:23 PM
Scootin_Z's Avatar
Scootin_Z
greg
Thanks for the info Greg (by the way this is Kurt Hill) When you have a chance send me that e mail on the logging set up. I don't think I got it yet. I am back from Power Tour and the car survived the trip from Madison to Baton Rouge (barely) I have some work to do. I really want this car "right" and I have not given up (YET!)
Old Jun 18, 2015 | 10:22 PM
Impala Balko
greg
Let me clear up some misconceptions from my original post...I am not blowing my dipstick out of the tube however some oil is blowing out the dipstick tube under high boost and i get some puffs of smoke out of the exhaust. How much is one of these modified pcv check valve things and how do i order them. I have a feeling that my check valve may be causing a too much of a restriction on the system because it may be too small and not allowing proper flow... what kind of check valve do i need.... here is the one I currently have
http://www.mcmaster.com/#7775k52/=xonspv
Old Jun 19, 2015 | 08:49 AM
BlowerWorks
Supporting Vendor
A good checkvalve is $15
I suggest you first cap off the PCV system and replace the oil dipstick with a new one.
Then if you have open breathers on each valve cover there should be no oil dripping from dipstick tube.
Are the puffs of smoke under WOT or when you lift ?
Old Jun 19, 2015 | 07:20 PM
Impala Balko
When I lift after I hit boost
To LT1 PCV system
Old Jun 20, 2015 | 09:07 AM
Scootin_Z's Avatar
Scootin_Z
who sells a reasonable but decent set of valve covers that has breathers on both sides? I'm running the stock set so I've only got the oil filler as a breather on the passenger side. Will that be enough with a catch can setup? and with proper breeders do you still need to cap the PVC system?Also anybody have pictures or ideas for their catch cans?
Old Jun 20, 2015 | 06:18 PM
illenema's Avatar
illenema
Default Pcv Valve
Need a good working Pcv system or the hydrocarbons will start to break down the detergents etc in the oil..
Old Jun 20, 2015 | 06:58 PM
BrianCunningham
I do have a decent pic of my breather setup
The long tubes are in case there is blowby, it won't start a fire
