Compression Ratio?
Old Aug 14, 2002 | 08:35 PM
UB2 SLOW's Avatar
UB2 SLOW
From: I could tell but then I would have to kill you
Default Compression Ratio?
With the below listed mods, what can I expect the compression ratio to be. The stock compresson is 10.4.
Old Aug 15, 2002 | 05:52 AM
gtsyellow's Avatar
gtsyellow
Default Re: Compression Ratio? (UB2 SLOW)
ask the guy who did your heads if they were decked. if they were not decked your compression is the same as stock or maybe 0.1 less from the chambers being worked.
Old Aug 15, 2002 | 12:52 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
If you went from a ~56-58 cc head to a 54.4 cc head, and nothing else changed, you probably added .2-.3 points. So you are probably somewhere in the vicinity of 10.6-10.7.
Here is one calculator...
http://www.rbracing-rsr.com/compstaticcalc.html
Old Aug 15, 2002 | 06:00 PM
UB2 SLOW's Avatar
UB2 SLOW
Default Re: Compression Ratio? (gtsyellow)
The guy is doing the heads now. I should get them back next week. What is decked?
Old Aug 15, 2002 | 06:45 PM
65Z01's Avatar
65Z01
He will shave a little off the heads where they attach to the block to assure flatness. If he takes off more than a few .001s he may need to also shave the intake base to assure a good matchup.
Old Aug 15, 2002 | 08:30 PM
gtsyellow's Avatar
gtsyellow
Default Re: Compression Ratio? (65Z01)
isn't 54cc the stock lt4 chamber?
Old Aug 15, 2002 | 08:42 PM
Sharky Guam's Avatar
Sharky Guam
You're probably not going to realize much of a difference. A couple cc's won't affect any noticeable change.
Be sure to mill the intake to match the heads. If your ports are mismatched, you will likely notice a loss.
:cheers:
Old Aug 15, 2002 | 10:00 PM
UB2 SLOW's Avatar
UB2 SLOW
Default Re: Compression Ratio? (Sharky Guam)
:cheers:
He has my intake, heads and the trottlebody. He is going to port & polish and make sure everything is matched. I am hoping for some serious flow. I ran the setup on Dyno 2000 software with 10.4 compression and it gave me 365 hp at 5500 and 435 tq at 4000. I am not sure how accurate the software is. After I get the actual flow numbers I will put them in and check again.
Old Aug 15, 2002 | 10:06 PM
Glasman66's Avatar
Glasman66
He has my intake, heads and the trottlebody. He is going to port & polish and make sure everything is matched. I am hoping for some serious flow. I ran the setup on Dyno 2000 software with 10.4 compression and it gave me 365 hp at 5500 and 435 tq at 4000. I am not sure how accurate the software is. After I get the actual flow numbers I will put them in and check again. [/QUOTE]
What is he charging you. I want to do the same and was wondering what it should run?
Old Aug 16, 2002 | 10:47 AM
UB2 SLOW's Avatar
UB2 SLOW
Default Re: Compression Ratio? (Glasman66)
What is he charging you. I want to do the same and was wondering what it should run?[/QUOTE]
He is charging me $500.00 for the whole thing. His web site is http://www.actionautomotiveinc.com.
To Compression Ratio?
