shiming hood
Old May 10, 2015 | 09:43 AM
msapp3ster's Avatar
msapp3ster
Default shiming hood
any help on how many shims for hood hinge on 85
Old May 10, 2015 | 09:48 AM
antfarmer2's Avatar
antfarmer2
They can change in a production run. Just put back as they were and go from there.
Old May 10, 2015 | 04:32 PM
msapp3ster's Avatar
msapp3ster
I would but I bought the car with out the hood and hinges installed.
Old May 10, 2015 | 04:39 PM
antfarmer2's Avatar
antfarmer2
Might just be a trial and error.
Old May 11, 2015 | 04:07 AM
gerardvg's Avatar
gerardvg
Hi
The hinges are usually left on the car, there are several shims.
My 85 has 3 shims on the drivers side rail, 12mm of shims in total.
The passenger side rail has 10mm of shims in total.
There are more shims where the hinge connects to the X frame, drivers side 13mm (3 shims) Passenger side 11mm (2 shims)
Do not know why they are different,the car has not been in any accidents.
It is a rough measurement, hopefully it will help you be in the ball park with shim sizes.
See the images below.
Old May 11, 2015 | 08:37 AM
antfarmer2's Avatar
antfarmer2
Just what you needed a starting point!!!!!
To shiming hood
