93 lt1 vette
Old May 10, 2015 | 10:38 AM
millers3dge's Avatar
millers3dge
Default 93 lt1 vette
Hi guys,
I just got a red devil ALDL usb to obd1 cable. And I,am trying to use tunerpro, I get all my coms set, and when I try to connect it says connect at the bottom then I get errors , and it goes back and forth , like it is connecting and disconnection.. I do the com test and it says it is,connected. But when I plug it to my car and I try the test it says fault baut rate 8173 fault. . unsure of what I am doing wrong.. Could it be my definition file?.
Also , can I tune my car with this? Like change rpm, air/fuel , ext...
Old May 11, 2015 | 12:40 AM
Cliff Harris's Avatar
Cliff Harris
Possibly. What definition file are you using?
You can only tune if you have an EPROM burner.
Old May 15, 2015 | 12:02 AM
millers3dge
Default definitions
I have tried 10 different ones. From 93 lt1 to 92 lt1, get the same result no matter what I do.
You can only tune if you have an EPROM burner.[/QUOTE]
Old May 15, 2015 | 12:14 AM
Cliff Harris
I don't know how the later ECM/PCMs work, but if it's like my car it starts out in 160 baud mode and then you have to do a handshake to get it to switch to 8192 baud. The 8192 baud handshake needs to be defined in the .ADS/.ADX file. I have not seen one that does this, but I assume they exist or people wouldn't be able to data log.
Your PCM uses an EPROM to store the program and operating parameters. To change anything (like idle speed) you need to be able to burn a new EPROM with the new parameter(s).
To 93 lt1 vette
