1986 horn wiring help
My 1986 vert has a horn issue.... fuse 15 amp is ok behind message center relay operates with horn button , verified with testlight , ohms read in millions from green wire at relay to left or right horn power wire ,if i send power down the green wire from relay still no horn op ,checked horn at itself it operates, so now i suspect the green wire as being broken somewhere. but i do not know where this wire goes from the relay to horn ie connector locations and harness locations and am i missing something in my checks ....thank you for helping
also looking for g5 c100 location
cheers!
auto store.....there is a horn relay....you may have blown it with the extra power....time for a gm factory manual if you don't have one...
In the engine compartment C100 has two connector plugs that plug into it.
One is the engine harness and the other is the lighting harness. My guess is the Dark
Green wire is in the lighting harness pin G5.
Have a great day!!
