Help! steel single mass flywheel problem
Not a corvette, but some time ago I bought a used 1ton pu (Chebby) diesel. Almost immediately the clutch pedal went to the floor- it blew the slave cylinder. Previous owner said he had previous probs w system so we took it to the dealer to fix. Now, this pu wasn't 20+years old like our C4's, so techs should still have had a clue on how to fix it....
After about a week of "we're still working with adjusting the slave cylinder" and other BS they finally called and said it was ready. Not 2 weeks later it happened again so they replaced the system again. Again it took far too long to fix, but they finally got it. Again it blew very quickly. After a few more times they finally told me they would no longer honor their repair and if it blew again tough s**t. I bought an aftermarket set and when I went to fix it I figured I'd check the clutch as well, as it had a REALLY heavy effort to depress the clutch pedal. (at least 1 or two times the dealer had supposedly pulled the trans to check it all out as well). When I got it apart I noticed the clutch fork didn't seem right. It turned out the problem was the ball on the clutch fork needed to be greased periodically (info is in the service manual) but had not been done because no-one could see the zerk fitting above the exhaust crossover pipe.
So the dealer 1, didn't maintain the vehicle properly; 2, didn't diagnose the problem correctly; 3, didn't even know how to properly do what they did to try and fix the problem anyway; (btw, every service manual I referred to for my work told me the clutch master-slave system was non-adjustable. So much for taking a week to "get it adjusted". They also told me the master, slave and line all came as an assembled unit and could not be obtained separately... more BS I found out later.)
Now, I'm not saying this dealer you're working with is as worthless as the one I was dealing with, but remember our cars are antiques to them, and the dealer mechs are primarily trained to work on the newer models to deal with warranty chit. Maybe you have a mech there that's been there a couple decades and remembers how these cars are... If not maybe you can find someone in the area who does have the experience you need. Too bad about your time crunch. I know how it goes.
Good luck.
I'm not sure about their diagnosis of a warped plate. The whole purpose of the dual mass flywheel was to absorb the natural chatter inherent in the ZF transmission, especially the pre '94 black tags, which you have.
With the single mass you are going to have chatter when the car is in neutral and the clutch is out. If it goes away when the clutch is engaged, or when you're moving in gear, it is probably normal. The only remedy I've heard of is a countershaft shim, but I'm not sure if it is available for the black tags. Note: The sound is best described as rocks in can, and it definitely could be mistaken for a problem.
As old as these cars are, it is very possible that the tech at the dealership is not aware of this little bit if info on this transmission, and naturally thought something must be wrong. These things are not quiet with the single mass flywheels, just a fact of Corvette life.
