Block off charcoal canister
Old May 16, 2015 | 09:13 PM
mlm0's Avatar
mlm0
Default Block off charcoal canister
I am triying to run down a possible vacuum leak at idle. Will it cause a problem or throw a code if I block of vacuum line from throttle body to charcoal canister selinoid ?
Old May 16, 2015 | 09:54 PM
playsdixie's Avatar
playsdixie
no...but easier to just spray the lines with TB cleaner....idle will pick up when you spray around the leak....
