hopefully someone can help
Old May 18, 2015 | 12:58 AM
86corvetteguy's Avatar
86corvetteguy
Default hopefully someone can help
I have been working on a 86E corvette that I purchased about a month ago, been updating everything and getting back to working order. I have came to an issue I can not figure out and hoping that someone can help. So I finally got everything back together on the motor after replacing the fuel injectors, and fuel pressure regulator. I start up vehicle and while its running, if you give it a little gas, just push down on pedal just a little bit, like if you were pulling out, it acts like it wants to die, but if you open it up on the throttle it acts fine, also acts fine just sitting there, just does it when you barely push down the pedal. What would cause this? Would it be a dirty or bad throttle body? Or throttle body sensor? I cant figure out.. please help.......
Old May 18, 2015 | 01:46 AM
Cliff Harris's Avatar
Cliff Harris
A vacuum leak will give those symptoms.
Old May 18, 2015 | 01:51 AM
86corvetteguy
Cliff any idea on where I should start looking? Ive replaced most of the vacuum hoses on the vehicle.
Old May 18, 2015 | 10:52 AM
Patsgarage's Avatar
Patsgarage
With the engine idling spray carb cleaner around all the vacuum lines/fittings. When the engine stumbles you have found your leak.
Old May 18, 2015 | 02:25 PM
94Z07's Avatar
94Z07
This is definitely one of the best ways to find a leak in my oppinion just used this technique on another car, no leaks, so i replaced the fuel filter. that solved my problem.
Make sure you don't get a false positive by spraying near your air filter, because that will stumble your car as well.
Old May 18, 2015 | 06:31 PM
playsdixie's Avatar
playsdixie
except the idle should rise when you find the vac leak, not stumble....I found several leaks that way....
Old May 18, 2015 | 06:35 PM
94Z07's Avatar
94Z07
Hmm if i spray it on my air filter, it will kill the engine, unless it's starting fluid, then it goes VROOOOM
Old May 18, 2015 | 09:29 PM
playsdixie's Avatar
playsdixie
guessing spraying on a vac leak seals the air out and raises the idle...into the tb itself would replace the gas which is a higher octane....on my car, it raised the idle when I found a leak....
Old May 18, 2015 | 09:47 PM
vl5150's Avatar
vl5150
Besides any leaks, are the injectors OK and correct for your car? That and the FPR is what actually changed so look hard there. What's the fuel pressure? Are all the sensors hooked back up correctly? I forgot one once and the car ran rough. Did you disconnect and reconnect the battery? When I ran without a sensor I think the computer learned to deal with it and the battery disconnect fixed it once I reconnected it.
I did my TPI several times and used regular gaskets with that purple gasket sealer and haven't had a problem.
Old May 18, 2015 | 11:20 PM
86corvetteguy
I've checked all vacuum lines, they are all fine, replaced every line. I have also have new fuel filter, new fuel regulator, I haven't checked my fuel injectors but I did get new Bosch injectors when I first started this process and was putting the car back together. Anything else anyone can think of? Like I said it idling it's fine, then if you just give a little gas it seems like it's going to die. I did let someone else look at it today to see if he could notice anything, he said he thought he heard a knocking noise from a fuel injector. How can I tell if the fuel injectors are good? How can I check to see if they are sticking? Also is there any chance that it could be something else? Please help... Giving me a major headache trying to figure this out.. Thank you
Old May 18, 2015 | 11:21 PM
86corvetteguy
Not knocking I meant clicking noise
Old May 19, 2015 | 02:18 AM
Cliff Harris
That's normal.
You can check your injectors by measuring the resistance of the coils. Remove the connector and the coils should measure about 15 ohms. Check all of them and if any are quite a bit lower than the others then you have a problem. Best to replace all if one or more are bad. Sometimes injectors will check OK when cold and then fail when hot, so check them both ways.
Old May 19, 2015 | 07:49 AM
ghoastrider1's Avatar
ghoastrider1
I am wondering if the TPS is on its way out.
Old May 19, 2015 | 07:52 AM
Churchkey's Avatar
Churchkey
If no vacuum leaks or CEL:
When changing over to Bosch 3's from FIC:
When starting the vehicle for the first time allow it to idle for 15 minutes before driving.
Suggest disconnecting the battery for several seconds to base line the ECU then follow the above procedure.
If the issue persists check the TPS setting. Key on engine off (KOEO) voltage @ the TPS
should be .54 volts. To check/adjust the TPS you will need 2 stick pins + a digital VOM.
The TPS check/adjust procedure is well documented on this forum.
Good luck.
Edit: Ghoastrider1 is faster than I am
Old May 19, 2015 | 10:37 AM
Patsgarage's Avatar
Patsgarage
Yes so true, this is why I should not post before coffee !
To hopefully someone can help
