Worn Serpentine Belt..would it cause any problems?
Old Aug 15, 2002 | 05:03 PM
TIMSPEED's Avatar
TIMSPEED
Default Worn Serpentine Belt..would it cause any problems?
Well, I was looking at my Belt Tensioner last night, and I noticed that the little pointer is at the VERY end of the "acceptable" range...so I guess that means that my serpentine belt is stretched out and needs to be replaced...right? I KNOW I have a BRAND NEW one laying around from my 85 (found it in the rear storage compartment). It's an easy thing to put on..but is it gonna make a difference? I mean...like..would a stetched belt affect my timing or whatever?
Old Aug 15, 2002 | 05:28 PM
Geoff13IOM6GS's Avatar
Geoff13IOM6GS
Default Re: Worn Serpentine Belt..would it cause any problems? (TIMSPEED)
no but it could start to slip or break and you'd lose all your accessories .... including power steering :eek:
Old Aug 15, 2002 | 05:29 PM
J Z06's Avatar
J Z06
It could break at some point. Mine had little cracks in it, so I decided to change it out. It's only $25 or so...Pop a new one on and be done with it. Better to be safe than sorry.
Old Aug 15, 2002 | 05:39 PM
VETTENV's Avatar
VETTENV
Cruise-In V Veteran
Cruise-In VI Veteran
Yep, it's a cheap and easy to do fix! :yesnod:
Old Aug 15, 2002 | 05:50 PM
all4c4lt4's Avatar
all4c4lt4
You could split the hell out of yours like I did mine when I downshifted from 6th to 4th on the highway (and stood on it!). I had pieces of the belt on top of the manifold. At some places, the belt was only 1/4 of its original width. I just thought I ran over some gravel when I heard the noise.
Mine wasn't in that bad of shape prior to that, just some cracks.
Old Aug 15, 2002 | 07:08 PM
vader86's Avatar
vader86
Default Re: Worn Serpentine Belt..would it cause any problems? (all4c4lt4)
Yes go ahead and replace it.
Old Aug 15, 2002 | 07:37 PM
Corvette0096's Avatar
Corvette0096
Replace it.. The belt can start come apart and cut into your hood.. :yesnod:
Old Aug 15, 2002 | 07:47 PM
Lone Ranger's Avatar
Lone Ranger
Why take a chance? Things never go wrong conveniently as you roll into your driveway after a long drive. Nope. They break and leave you stranded out in the sticks with a hundred miles from civilization, where the only nearby people are in-bred banjo pickers...
SO I would replace it if it were me, 'cause I wouldn't want to be stuck somewhere with Cleetus laughing when Cooter tells me to Squeal Like a Pig. :eek:
Old Aug 15, 2002 | 07:48 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: Worn Serpentine Belt..would it cause any problems? (corvette0096)
Replace it. If you don't some of the pieces might sling around and damage something else like a wire or a hose. Plus it is cheap insurance to know that you won't be stranded somehwere because of it. I would hate to have to replace it on the side of the road while the engine is hot.
:D
Old Aug 15, 2002 | 08:00 PM
M2001's Avatar
M2001
When my belt wore out, it looked fine from the outside however, the inside of the belt was worn to the cords. This caused me all kinds of power steering problems on the track. The power steering would quit intermittently in the middle turn causing me to break the rhythm of following a line. I had no confidence going into any full throttle turn. My track times suffered because of that lousy $25-30 part.
I thought I had a bad power steering pump when all it turned out to be was a worn belt.
Old Aug 16, 2002 | 12:55 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: Worn Serpentine Belt..would it cause any problems? (M2001)
hmm..I'll replace it in the morning!
Old Aug 16, 2002 | 02:43 AM
Voltech_LT4's Avatar
Voltech_LT4
Cruise-In IV Veteran
how do you get the belt off? where is the tensioner on a 96? Is it down in the middle in front of the water pump? just curious....
Old Aug 16, 2002 | 06:48 AM
Grand Trunk's Avatar
Grand Trunk
Veteran: Marine Corps
Default Re: Worn Serpentine Belt..would it cause any problems? (Voltech_LT4)
As you look at your engine from the driver's side, following the belt countercolckwise, the belt goes over the a/c compressor, then the alternator, then under the power steering pulley. The next pulley you see is the belt tensioner. The tensioner has a bolt looking thingy on the front of it. This is where you put your wrench and pull toward the driver side of the car to relieve the belt tension.
To Worn Serpentine Belt..would it cause any problems?
