Question... Weird issue
Old May 25, 2015 | 04:40 PM
toochowed's Avatar
toochowed
Default Question... Weird issue
Hey guys... ran into an odd issue on a trip this weekend. my 91 had its AC compressor go out, it started making noise and the belt went. Got that all fixed up. As this happened, the climate control center lost power, it does not work anymore. Also at the same time, the gas gauge doesnt seem accurate, it didnt move for 200 miles, and all the features like trip ODO etc, none of those buttons do anything now. Where it says how many miles left on my tank, it blinks "SYS" instead of the number every minute or so.
Any idea what happened or what to check to make that work again? Going to suck not having a gas gauge.
Old May 25, 2015 | 04:44 PM
antfarmer2's Avatar
antfarmer2
Try unhooking you neg battery conection wait ten min then hook it back.
Old May 25, 2015 | 04:48 PM
toochowed's Avatar
toochowed
will go try this now. thank you will report back result!
Old May 25, 2015 | 05:06 PM
toochowed's Avatar
toochowed
ok so I tried this.... i dont know how much gas I have so I dont know if its right, and the miles left changed to the instant MPG reading, but still cant get any of the buttons to do anything and still blinks SYS.
Old May 25, 2015 | 05:10 PM
toochowed's Avatar
toochowed
this all started instantly after the climate control went out. none of those buttons work and the outside temp reading is gone. is there a fuse for the climate control center?
Old May 25, 2015 | 05:21 PM
antfarmer2's Avatar
antfarmer2
Not sure and storming here. Might be a bad ground. Might have fried your alternator can you get it checked
Old May 25, 2015 | 05:27 PM
8a8mfh's Avatar
8a8mfh
If it blinks sys you should be able to read stored codes.
Old May 25, 2015 | 05:33 PM
antfarmer2's Avatar
antfarmer2
If it was me I would pull the neg cable again and charge and check the battery then the alternator
Old May 25, 2015 | 05:36 PM
antfarmer2's Avatar
antfarmer2
read the codes first.
Old May 25, 2015 | 05:48 PM
toochowed's Avatar
toochowed
ended up being the A/C fuse, must run the other set of buttons to. thanks!
Old May 25, 2015 | 06:09 PM
antfarmer2's Avatar
antfarmer2
good job cheap and easy.
To Question... Weird issue
