LT1 tach question
Old Aug 15, 2002 | 11:50 PM
737driver's Avatar
737driver
Default LT1 tach question
I'm thinking of doing an LT4 conversion to my LT1. Lingenfelter advertises $299 to change the tach to 8000 rpm. Seems like alot of money. Will the stock tach register above the top mark at 6000rpm? It looks like the edge of the bezel would be about 6500 rpm. I don't intend to go above that.
Bruce
Old Aug 16, 2002 | 12:35 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: LT1 tach question (737driver)
Keep in mind that our tachs are off by as little as 200 rpm to as much as 500 rpm on purpose. GM did this to keep us guys from pushing it too far.
I regularly push mine past 6000 before the rev limiter kicks in.
I'm guessing mine is off by about 200 rpm.
Old Aug 16, 2002 | 01:23 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I have bounced mine off the speedo when I had the solid roller cam in the motor. I generally run it a bit past 6K on the tach. Mine is off by 2-300 like Franks'. I use the shift light to tell me when I go far enough ;).
Old Aug 16, 2002 | 01:40 PM
TealBlueEyes's Avatar
TealBlueEyes
Default Re: LT1 tach question (Mr Mojo)
They're intentionally inaccurate?!? - always on the high side I guess... Is this true? Why the heck would you do that? You've already got a rev limiter and the resolution is so crappy on the gauge (lack of needle movement and markings) that you'd think it'd at least be accurate. You really have to wonder about GM sometimes. :smash:
Jim
[Modified by TealBlueEyes, 12:45 PM 8/16/2002]
Old Aug 17, 2002 | 01:07 AM
737driver's Avatar
737driver
Default Re: LT1 tach question (TealBlueEyes)
Thanks for the info, a shift light seems like the way to go. Who sells them?
Bruce
Old Aug 17, 2002 | 03:39 AM
STL94LT1's Avatar
STL94LT1
harlan-engineering.com
To LT1 tach question
