A/F ratio readings
Old Aug 16, 2002 | 12:44 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default A/F ratio readings
Can anyone clarify this for me?
http://forums.corvetteforum.com/zerothread?id=365152
Old Aug 16, 2002 | 01:13 AM
ChrisB's Avatar
ChrisB
Default Re: A/F ratio readings (Red 90 L98 Coupe)
Your reading was skewed because of the CAT, but at 10.8 I doubt it was skewed enough to render his conclusion incorrect - even through a cat 10.8:1 is more than likely rich.
You should be able to look at your plugs for confirmation
Old Aug 17, 2002 | 06:21 AM
The Dingo's Avatar
The Dingo
Default Re: A/F ratio readings (ChrisB)
Thanks. :cheers:
I had no idea my A/F could be so far off. Guess I have to do some tuning...
To A/F ratio readings
