A guy in SW FL with true duals behind his L98 made runs at the strip with RT cats and without and no diff; he still ran 12.0xx sec. Of course he had TPIS headers too to tune the exhaust flow.
If your stock cats are healthy you probably won't see much difference. If you gut them you could see a loss because of increased backpressure caused by increased turbulence. You can avoid this by putting a straight pipe through the gutted cat to make it act like a straight pipe.
Headers can give a very nice increase as well. The problem is that it's harder to rig cats onto a set of full out long tube headers. Not impossible, just more difficult. Most people who have put a set of high flow cats on their headers haven't noticed any substantial power loss.
So what I guess I'm trying to say is that healthy cats are not a huge exhaust restriction. I don't run them because I have long tube headers. I could, but it would be very costly. As such we don't have local emissions checks, I'm not going to worry about it.
I wouldn't do it. 3 reasons why:
1. Believe it or not, you will loose torque.
2. You will get an aweful smell because the cats are not burning any of the toxic gases being produced from the engine.
3 You will be releasing a lot of harmful emisions. And that is not good.
Just my .02
depending on the year of the car and the state you're in. You could qualify for show car insurance which grants you the ability to get an emissions waiver. Then you can do what you want :D
your insurance will also be cheaper, you can set the amount of the cars worth instead of relying on the "book" value (which is typically lower than the amount of any mods) and the mileage is pretty gratuitous. between 5000 and 7500 miles a year allowable.
This is not true, there was a great article in Hod Rod Mag that debunked this old tale. For an exhaust to add power it must either scavage exhaust gas from the cylinder or reduce back pressure. Cats do add back pressure, though modern cats don't add measureable backpressure to a stock LT1/4 with exhaust manifolds. The bottle neck is the exhaust manifolds. Certainly, cats do not provide any scavaging of exhaust gases.
My bad, now I see you have an LT1 with dual cats, not an L98 with main cat and two pre-cats.
In this case I would suggest a pair of hi-flow cats as a mild upgrade; better would be full-length headers. You could always add a pair of hi-flow bullet cats for emissions if needed.
Hey silver & red CE, no flame intended, but do you believe eveything you read? I have seen actual dyno results, not read it in an article. I read in the Mustang and fast ford magazine they hit 13.3 at 101 with a completely stock convertible 2001 cobra. That is near impossible. I know a guy who can drive his 01 cobra coup abd he is hitting 311 rwhp and his best time is 13.39. Again no flame intended. I would suggest going with high flow cats. 2 cats are better than 4 if that is what the vett's have. That is for hp.
LT1 vettes have 2. Only Fords burn so dirty that they must have 4 or 5 cats :)
Seriously there is a little power to be had, but very little. Unless your cat is clogged or you're putting headers in it's really not worth the effort of removing them.
Ditto on the overzelous environmentalist. In the misguided cause of ridding this planet of a plague (human kind) they have reeked havoc on industry. There must be an equitable balance between environmental protection and our rights for free enterprise, places to live, and pursuit of happiness. All that aside here is another view on removing the catalytic converter(s).
OK so there is a big debate on to remove or not and there have been many interesting and viable arguments. How about this…should you decide to sell the car you have now limited the places where the car is legal.
Hey silver & red CE, no flame intended, but do you believe eveything you read....
Cobra-boy, post the dyno results, I'd love to see them. And try your best to behave with a little class, this isn't some pimple faced rustang flame fest forum, we're Vette owners.
I'm not a tree hugging hippie by any stretch. But I feel as if we have a responsibilty to use a technology that is healthier for the environment. For me gaining a few extra HP is not worth it. Lets face it, have you ever driven behind an old car and choked on his or her exhaust smell?
DONT completly blame the converter or lack of one for the nasty smells or high emmission output. Both smells and emissions are the byproduct of unburned fuel the result of poor combustion. That is the whole purpose of a converter to clean up the leftovers. With OE exhaust and no engine mods my HC count was 4ppm @idle 49ppm @steady 2000rpm. After stat, rockers,and hollowed cat, HC count went to 18ppm@idle and 35ppm@2000 oh by the way dont smell anything either.
