Shock Question
First, I'm not a mechanic but, I am mechanically inclined and relatively skilled with mechanical things once I learn. I've decided to replace the shocks and start with the easier (or so I've learned) front shocks.
First, can they really be replaced without even jacking up the vehicle? If so, is the removal and installation as straight forward as it appears when I look at them?
Second, when looking at Ecklers they have Bilstein fronts for Z51 suspension and others without Z51 suspension...here's where you guys get frustrated with the newby mechanic...how do I know which ones I need and what is the difference. Could I get either one? I don't think I have Z51 suspension, but I really have no idea for certain. Can I tell by looking at the shocks on my car?
Thanks in advance for any information you guys pass along and also thanks for the patience. Any other tricks or information to help the process go smoother would be much appreciated as well.
I just love working on this thing. Each thing I do leads to another and she gets better with every project, so far anyway. Most projects came from reading posts on here, realizing they needed to be done, and gaining the knowledge to carry them out. Thanks a ton everyone for fueling this enjoyable addiction.
There was a TSB released in Dec '95 but it mentions '95 & '96 Chevrolet cars NOT just '96.
The Bilstein package can be sometimes priced very competitively from several vendors. I don't believe it could be said that anyone has the "best price" all of the time. Service from any vendor is sketchy. I'd make sure I confirmed before paying if they were "in stock" or when they would be delivered.
How many miles?
NO
YES
YES, both are direct fit.
NO, Look for the RPO codes, compartment behind passenger seat.
QUOTE]
NO
YES
QUOTE]
Do you happen to know what RPO codes to look for for non-Z51 and Z51 suspension?
Thanks again for the help and info...
http://www.lbfun.com/warehouse/tech_...PO%20Codes.pdf
There will also be one in your FSM - Try something near 0A-11 or 12 for a '92. Near the front in "introduction".
