Head gaskets - LT4 (dealer or ?)
Old Aug 16, 2002 | 03:12 PM
ericcer's Avatar
ericcer
Default Head gaskets - LT4 (dealer or ?)
I found out that the dealer shows a different part number for the LT4. Should I go with the LT4 GM gaskets or local auto parts brand?
Old Aug 16, 2002 | 03:43 PM
Arisa's Avatar
Arisa
Default Re: Head gaskets - LT4 (tdock)
I putting mine back together with the LT1 Impala head gaskets. I decided on that after talking with several people on the LT1edit mail group.
Just FYI
Neal
Old Aug 16, 2002 | 05:12 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
I believe the question is about head gaskets not intake manifold gaskets. P/N 12367777 is the intake manifold gasket.
I understand the LT1 head gasket is approximately .010" thinner than the stock LT4 head gaskets. This increases the compression and combustion chamber squish/turbulance. However, I am not sure it this is a good thing for the already high LT4 compression. Anybody do this?
Old Aug 16, 2002 | 05:15 PM
scorp508's Avatar
scorp508
"GM has 2 different sets of intake gaskets for the LT4, the stock ones (P/N 12528884) and the "Performance Parts" ones (P/N 12367777). The ones with the larger ports are the GM Performance Parts gaskets. I got mine from Jeff Kopp for something like $14.69 each, you'll need two. I used Felpro for most of the other gaskets, but GMPP for the intake."
He said head gasket, you're saying intake gaskets. :crazy:
Old Aug 16, 2002 | 05:26 PM
ericcer's Avatar
ericcer
Default Re: (scorp508)
Is the brand of HEAD gaskets important? Should I go with GM or the NAPA?
BTW, I do have the better intake manifold gaskets. :D
Old Aug 16, 2002 | 05:29 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: (ericcer)
I would go with fel-pro.. they seem to be the strongest (and most expensive) of the gasket brands.. Just make sure you get the right set.. I was sold a set of Chevy Small Block Fel-Pros.. not right..
-Mark
Old Aug 16, 2002 | 06:54 PM
LT4POWR's Avatar
LT4POWR
I'm not 100% sure, but I think the thickness is:
.049 GM F & Y bodies (aluminum head)
.029 Impalla (non-aluminum head)
.039 Felpro part# 1047
I'm going with felpro :D
Old Aug 16, 2002 | 07:19 PM
RichS's Avatar
RichS
Default Re: (LT4POWR)
I used the Felpro gaskets.
Old Aug 16, 2002 | 07:43 PM
ericcer's Avatar
ericcer
Default Re: (RichS)
Do you recall if Felpro gaskets are the same for LT1/4? Autozone list one Felpro but NAPA (their own brand) list two for 1996. I trust you guys more than some Autozone counter help.
Old Aug 16, 2002 | 07:48 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
My guess is they are the same.. but I might be wrong.. in fact, I would trust a NAPA counter guy, more then myself.. ;)
-Mark
To Head gaskets - LT4 (dealer or ?)
