Rough Estimate
Old Jun 4, 2015 | 12:44 PM
Bulldogger's Avatar
Bulldogger
Default Rough Estimate
Stock LT1 block, 1031 AFR heads LT4 hot cam with 1:6 roller rockers 52mm TB, Stainless works header 1-5/8 primaries, Bosch injectors and PCM for less tune.
Any idea on horsepower and torque? for this set up.
Old Jun 4, 2015 | 06:02 PM
8a8mfh's Avatar
8a8mfh
Originally Posted by bulldogger
stock lt1 block, 1031 afr heads lt4 hot cam with 1:6 roller rockers 52mm tb, stainless works header 1-5/8 primaries, bosch injectors and pcm for less tune.
Any idea on horsepower and torque? For this set up.
319/328
Old Jun 4, 2015 | 06:53 PM
aminnich's Avatar
aminnich
Old Jun 4, 2015 | 11:56 PM
STL94LT1's Avatar
STL94LT1
340 rwhp +/- 10hp.
Old Jun 5, 2015 | 09:24 AM
Bulldogger's Avatar
Bulldogger
Originally Posted by STL94LT1
340 rwhp +/- 10hp.
I thought the 1031 eliminater heads were suppose to be pretty good, and would have supplied better horsepower numbers.
Old Jun 5, 2015 | 12:44 PM
856SPEED's Avatar
856SPEED
310-340 rwhp....maybe matching torque......
Let us know for sure with a dyno sheet ����
Old Jun 5, 2015 | 02:10 PM
THE 383 admiral's Avatar
THE 383 admiral
I would say much more 350 - 360RWHP my LT1 is calculating 321 RWHP. DATA master Dyno log 350 HP range. Only major mod is my PCM tunning, Res del Nill, S.S mufflers Zero, SLP cai few points along with ram air, LTCC few more points, FORD Inj after tunning possible few points.
To Rough Estimate
