Valve Covers
Old Aug 16, 2002 | 06:16 PM
Crazy Canuck's Avatar
Crazy Canuck
Default Valve Covers
It's time I repainted my valve covers. I think at one time someone used some degreaser on them and part of them turned brown. What paint should I use and what process should I use to make them look original?
Old Aug 16, 2002 | 06:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Valve Covers (Crazy Canuck)
For my Mg '88 center-bolt covers I used carb cleaner to degrease them then wet sanded with 220grit and finished up prep with a laquer thinner wipe.
I then shot em with several medium coats of valve cover paint from MAD (two cans of it so I'd have enough), wet sanding between coats. That was last Fall and still looking good.
I didn't take them down to bare metal, just smoothed them out a little and assured they were clean.
Old Aug 16, 2002 | 07:20 PM
gtsyellow's Avatar
gtsyellow
Default Re: Valve Covers (65Z01)
you might check around your area for a powder coater, i paid $25 to have a set of mag's powdered bright red. it blows paint so far out of the water it's not even funny.
Old Aug 17, 2002 | 03:56 AM
87Beast's Avatar
87Beast
Default Re: Valve Covers (gtsyellow)
Powder coat them...I tried using a high temp paint that eventually became discolored. It's not worth it, if you powder coat it should last a long time.
Old Aug 17, 2002 | 10:44 AM
chucks88's Avatar
chucks88
Default Re: Valve Covers (87Beast)
I cleaned them with un-diluted Simple Green and painted them with POR15's aluminum high-temp engine paint. It is brushed on. People who see the covers on my car don't believe it's brushed on. It wets-out quite nicely.
Old Aug 17, 2002 | 12:24 PM
Corvette0096's Avatar
Corvette0096
Here is a idea, $101 at Sallee Chevrolet.
Old Aug 17, 2002 | 12:48 PM
scorp508's Avatar
scorp508
The top one is how they looked when they came off the car (you'll notice I busted it when snapping out the drip tabs for my 1.6 rockers, good thing I had another set).
The bottom one was after a quick wire brush to prep, Rustoleum Primer, and Rustoleum semi-flat black.
Old Aug 17, 2002 | 01:56 PM
Ramjet's Avatar
Ramjet
Default Re: (scorp508)
scorp, nice... :yesnod:
To Valve Covers
