Need help diagnosing ABS system
Old Jun 9, 2015 | 12:23 AM
fast.asleep's Avatar
fast.asleep
Default Need help diagnosing ABS system
I cut an orange wire under the rear tray a few years ago thinking it was something it wasn't. (Colour blind) The next time I started the car the ABS light stayed on and the ABS system was dead. I turned off the car and reconnected the wire but the ABS system is still dead and the light is still on. The BRAKE fuse looks ok.
The car is a 1987 auto
Any suggestions?
Old Jun 16, 2015 | 11:30 PM
cuengineer's Avatar
cuengineer
Are you sure the wire you cut was not pink? If so, it goes to the ABS system beneath the compartment behind the driver's seat. I can't remember offhand which fuse, but it is a very important circuit that involves a lot of sensors but is not connected to the BRAKE fuse. I found this when I had a blown fuse and realized there was a short in a circuit. After days of searching and following the wire all over the care including around the back of the hatch, I found the problem was short was in the ABS brake relay in that compartment.
Old Jun 17, 2015 | 12:18 AM
fast.asleep
Actually there was a pink wire was cut. I reconnected them all but still nothing. Do you have more info on where that relay might be? (I can't find my FSM)
Old Jun 17, 2015 | 11:50 AM
cuengineer's Avatar
cuengineer
If you take the plastic bucket out of the compartment that is in the floor behind the driver's seat, you will see most of the ABS brake system, i.e., the pump and most of the electrical devices. The ABS brake relay that the pink wire connects to is mounted down in there. If I remember right, it is on the front side. My relay was shorting out causing the fuse to blow on that circuit. It is not the actual brake circuit but is part of the control circuit that actuates other stuff.
Old Jun 17, 2015 | 01:32 PM
DanZ51's Avatar
DanZ51
Either A: your wire repair was not adequate. or B: you have another ABS problem that just happened to show up.
I would probably have another go at the wire repairs, and/or verify they are good. Next is to (ohm) check all your wheel sensors.
Old Jun 17, 2015 | 02:02 PM
cuengineer's Avatar
cuengineer
Also, there is an extensive ABS trouble shooting section in the FSM if you can find it.
Old Jun 17, 2015 | 06:26 PM
fast.asleep
While B is possible, A is far more likely. I'll check again tonight
Old Jun 19, 2015 | 10:40 AM
fast.asleep
It looks like my ABS and climate control issues are related. The wiring repair was good but I missed a couple of wires. The way I initially repaired it blew the GUAGES fuse killing my climate control. I'm wiring and testing now but I'll report back with what I found
Old Jun 19, 2015 | 08:52 PM
fast.asleep
I found it. The ABS wire is pink with a black stripe and it was cut as well. I repaired the wire and the ABS light went out
Thanks all
Old Jun 20, 2015 | 11:53 AM
DanZ51's Avatar
DanZ51
Thanks for the follow up. Nothing worse than a thread with no conclusion
To Need help diagnosing ABS system
