1987 ith a new issue
Old Jun 9, 2015 | 08:17 AM
Odontia32m's Avatar
Odontia32m
Cruising
Default 1987 ith a new issue
59K miles, had it one month. Thanks for the help on the other issue.
When I got it the hot to cold on the climate control was very stiff, but all worked. Now the heater motor does not blow on the heat setting and the heat control does not worked. The AC still blows cold on max, norm, the vent blows but again no thermostat control.
I have read threads on these issues but not both at the same time.
Thanks in advance
Old Jun 9, 2015 | 07:35 PM
Odontia32m's Avatar
Odontia32m
Cruising
Default Update it is the heater control valve non digital control panel
Thanks in advance
I was wrong the heater does work in heat mode. The heater control valve does not work. If manually extended it does heat and when put on cold it retracts and cooler air starts. I lubed and worked it with WD40 but it will not extend when put on heat.
Any ideas would be appreciated.
Old Jun 9, 2015 | 10:24 PM
Odontia32m's Avatar
Odontia32m
Cruising
There is strong vacuum when in the cool setting.
Old Jun 12, 2015 | 09:17 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
somebody will reply whos shared your problem. so far i havn't had this issue.
Old Jun 14, 2015 | 07:40 PM
Odontia32m's Avatar
Odontia32m
Cruising
Thanks,
I am going to replace the heater valve with one from a 75 pickup like I found out how to do on here.
Old Jun 15, 2015 | 12:39 AM
VikingTrad3r
Oil Producer
a 75 pickup shares a part with the c4?
Old Jun 15, 2015 | 02:33 PM
Odontia32m's Avatar
Odontia32m
Cruising
Sorry 82-84 pickup. It is here and a great write up with good pics.
Old Jun 15, 2015 | 02:36 PM
VikingTrad3r
Oil Producer
do you have the link?
Old Jun 15, 2015 | 04:09 PM
Odontia32m's Avatar
Odontia32m
Cruising
https://www.corvetteforum.com/forums...-corvette.html
To 1987 ith a new issue
