What engine block
Mike
350 chp is not a lot, so no special block needed for that. Even a basic 2 bolt block would work fine for your goals.
Mike
What Tom says is true, any 1985+ original SBC block will do. If you get a 2 bolt block and really think you need 4 bolt strength on the bottom end you can drill it out for splayed steel main caps. A block so retrofitted is actually stronger than a factory 4 bolt block.
Anyway, once you get a block you will want to take it to a machine shop and have it cleaned and inspected to make sure it isn't cracked or otherwise not rebuildable. Then you should have it decked, bored and honed and once that is done you will know what oversize pistons you need. Most of the time you can get away with .030" over, but you could go .040 or even up to 0.060 over if you wanted to build a bigger displacement engine (no replacement for displacement). If you get a crank with the block you'll want to have it cleaned and inspected first and then ground and then you'll know what size bearings you need... If you don't get a crank you can decide whether to go stock 350 or stroker like a 383. For 350 HP you can get away with a nodular iron crank... If you were wanting more than that or to turn high RPMs then you'd want to spring for forged steel. If you're going stroker you'll need to have the bottom of the block notched for rod/rod bolt clearance. Anyway... for pistons and rods there are lots of choices... Cast, Hypereutectic, or Forged... you probably don't need to go forged for a 350 HP build, but cast probably isn't a good choice for longevity. With 64cc chambers you should probably go with flat top pistons unless you want to need premium at least if not race gas. You don't need domed pistons to get 350 HP.
Anyway... you'll want a good set of aluminum heads, probably with 64cc chambers, 190cc port size, 2.02 intake, 1.6 exhaust. Those are pretty common specs. I'd go with a hydraulic roller cam with a grind suited to the RPM range you plan to use it in -- you don't need anything exotic for 350 HP, 1.6 ratio roller rockers, double roller timing set...
You don't say what induction or ignition you are planning to run... I'm assuming some kind of HEI distributor and probaby a stock-ish TPI? If so you may need to put in at least a high output coil in the HEI and you may need some upgrades to the TPI to get 350 HP.
Anyway... 350 to 400 HP out of an sbc isn't tough... pretty simple tried and true formulas to get there.
All i'm sayin' is be careful. I used the plastic cover, and it kisses the water pump.
If you read the link that you posted, you'd see that there are no issues w/double roller timing chains as the block is the same as all other SBC blocks -as I said above.
Block:
Vortecs used GM's -880 castings, it's basically a "traditional" cast iron SBC block with provisions for a roller cam and a one-piece rear main seal. Being "traditonal" means that almost any GM SBC part will bolt to it. One thing to watch for though, the timing covers. The Vortec uses a plastic timing cover that uses uses 8 bolts. Regular timing covers use 10 bolts. Some blocks had all 10 holes drilled and tapped, while others only had 8. The timing covers will still interchange, and somewhat seal decently.
With that being said, I would just like to restate that ANY small-block cam will fit. Whether it be the older flat tappet cams, the LT-series cams, or roller cams. Any rotating assembly provided it is a one-piece rear main. Any SBC water pump, flex plate, heads, distributor, etc...
Your posts are adding confusion where there needn't be any.
http://www.thirdgen.org/forums/engin...-chain-fitment.
I've done this build. I'm just trying to tell the OP things aren't always as straight forward as the internet says they are. Also, the stock oil temp sensor does not fit in the stock location. I haven't checked, but i think the treads in the block are metric, anyway, the hole is way too small. I used a new plastic cover because i wanted it to seal well, not "somewhat decently".
The requested page was not found.
It's good of you to try to help give a heads up, but it would be a lot MORE helpful if you'd provide complete and accurate details, rather than dropping a bomb such as
"Watch out for the little things, though. For instance, a double row timing chain won't fit on a truck "vortec" block without modification to the block."
..>Then leaving it at that. First, there is no solution or explanation of the problem. Second...it ain't TRUE! Ya DON'T have to modify the block to get a double row timing chain to fit! You MAY have to use a different timing cover (which solves the second issue that you posted -the timing mark) and as it turns out, you're not supposed to reuse the plastic cover anyway...b/c it will leak.
So I don't think that you dodged any bullets there. Threaded holes in block for Oil fittings are NPT. This is true for older SBC's and Newer, "Vortec" or not. There is nothing special about the "Vortec" block...it will work just fine for a swap. I've done it too, into an '84, and even used the Vortec heads w/the stock CFI intake. .
That search worked, and apparently it's true. Grinding is required it appears. I apologize for my spreading of misinformation. Not good. Thanks for providing the right search criteria to get to the info.
