I am thinking of doing some data loging and would like to now if this combo would work.
http://www.ebay.com/itm/121471550880?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/GM-OBD1-Scanner-Cable-Software-USB-to-16-pin-ALDL-direct-GM-OBDI/121601381757?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D777000%26algo%3DABA.MBE%26ao%3D1%26asc%3D31190%26meid%3D759b08d6131f42a79f24bd382edb7d70%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D110847908943 https://play.google.com/store/apps/d...ldldroid&hl=en
Ok i got this tablet http://www.ebay.com/itm/331514969904?_trksid=p2057872.m2749.l2649&var=540680888870&ssPageName=STRK%3AMEBIDX%3AIT instead with shipping it was cheaper. I just tried a short data run log out in the garage as far as I can tell it works but is not reading my data correctly so I have to lern how to configure aldl and wether to use or not use the jumber on the scanner cable.
by the way I have a 90 L98 auto
Reason: ad car info
You need the correct data configuration file so the software knows what its looking at. The PCM spits out a string of digits. The order and meaning of the digits changed from year to year so you need the correct configuration file or you'll get garbage.
I am using ALDLDroid, the jumper for the resistor is built into the usb cable that I am talking about, I found the right adx file on the disk that comes with the cable from reddevilriver, Yes I found out about the garbage. thank you.
I did some data logging with what I thought was the correct adx file but I noticed the oil temp reading high right from a cold start up 148, BLM at 125, IAC 11, I am trying to diagnose a rough idle, MAP kPa 35.08, MAP Voltage 1.31, TPS % 0.0, TPS Voltage 0.92, all taking at idle with engine warmed up. let me now what other data I should be looking at. also should there also be data letting me now if the tcc is locking up. thank you
