1985 C4 antenna cable plug broke off
Old Jun 13, 2015 | 09:24 AM
Fieroaddict's Avatar
Fieroaddict
Default 1985 C4 antenna cable plug broke off
The silver plug on the antenna cable broke off of the cable from the antenna.
Can a new cable be bought?
The plug can't be taken apart otherwise Id try the solder the thin copper wire back in it...
Please help. Thanks!
Old Jun 13, 2015 | 09:40 AM
antfarmer2's Avatar
antfarmer2
Car Radio Antenna (Motorola Connector) Plug
$1.49
Part Number: VAN-MP2X
Add to Cart
Click to enlarge
Motorola Plug for Motorola antenna connectors
Fits standard car radio antenna cables. This is a hard to find item, perfect for situations where you need to replace the Motorola antenna plug on car stereos antennas, etc. Solder tab and crimp on rear of connector. Fits RG-59 Type coax
Measures: 9.0mm (Diameter) x 53.81mm (Long - including tip)
QTY: 1 Connector (Two pictured)
Old Jun 13, 2015 | 09:55 AM
Fieroaddict
That wont work. It wont connect to the interior wire.
Needs to be specific to the vette and not a universal plug end.
Old Jun 13, 2015 | 09:59 AM
Fieroaddict
Here is the connector.
Old Jun 13, 2015 | 10:11 AM
antfarmer2's Avatar
antfarmer2
Could you go with universal and change both ends? Or just cut both off and solder and seal
Old Jun 13, 2015 | 10:15 AM
Fieroaddict
I could but Id rather not cut up anything I don't have to.
Old Jun 13, 2015 | 11:05 AM
antfarmer2's Avatar
antfarmer2
I understand that get a new antenna.
Old Jun 13, 2015 | 11:47 PM
Cliff Harris's Avatar
Cliff Harris
I broke the same connector and was able to find a used cable. Part number 22038695.
Old Jun 14, 2015 | 12:20 AM
Fieroaddict
Someone wants to sell me an antenna as a core for the cable but I only need the cable. Rather not spend money on a whole antenna for just the cable.
Ill look up the part number. Where did you find yours?
Old Jun 14, 2015 | 07:46 AM
antfarmer2's Avatar
antfarmer2
Not sure if your is the same as my 94 the antenna is a pita don't want to do it again.
Old Jun 14, 2015 | 09:36 AM
Fieroaddict
The 90's c4 had a different antenna and plug ends
Old Jun 14, 2015 | 09:40 AM
antfarmer2's Avatar
antfarmer2
But I belive they are in the same place might be better to put in new than to have to do it again.
Old Jun 14, 2015 | 09:46 AM
Fieroaddict
There are no new cables for my style plug cable. Have to buy a whole new antenna.
Just rebuilt it and it works great.
Old Jun 14, 2015 | 11:42 PM
Cliff Harris
I don't remember. I found somebody with Google that had one.
To 1985 C4 antenna cable plug broke off
