Cylinder heads!
Old Jun 13, 2015 | 09:05 PM
Drautotech's Avatar
Drautotech
Default Cylinder heads!
The cylinder heads on my car are cracked and i need to buy replacements. I was thinking about going with the stock ones but i can't find any anywhere!!! So I might try performance heads! What do you guys recommend? What are some good brands for performance heads? Could I use my stock intake with them?
Dave C
Old Jun 13, 2015 | 10:35 PM
project C4's Avatar
project C4
http://www.summitracing.com/parts/edl-60879
Old Jun 13, 2015 | 10:36 PM
project C4's Avatar
project C4
or your heads...
http://www.summitracing.com/parts/nal-12556463
Old Jun 14, 2015 | 06:58 AM
jlfx car audio's Avatar
jlfx car audio
What year motor you wrenching on? I'm pulling my 90k mile aluminum 128 heads of my stock 86 convertible pretty soon to do a build if your interested in them shoot me a pm
Old Jun 14, 2015 | 10:24 AM
John A. Marker's Avatar
John A. Marker
Give us the year of your car....important information.
I would go with a performance head with at least 180 cc for a stock engine. Would not go to 190's unless you have a good cam.
Heads are also a matter of how much you want to spend. Personal preference is AFR.....but your going to spend $1500 or so on heads of this quality.
Old Jun 14, 2015 | 12:19 PM
project C4's Avatar
project C4
he has a 90 model motor which has 113 heads. (58cc chambers)
the two I listed are replacement heads with no drama.
one factory and one a little better without altering his compression ratio. Afr offers a small chamber head but it is special.
Old Jun 14, 2015 | 03:55 PM
BOOT77's Avatar
BOOT77
I'd spend the bit extra and get some summit/jegs house brand alum or other base model alum heads like dart SHP. Even if the new head chamber is a little bigger it'll outflow those stockers and more than make up for it. Nothing china!
edit: ARF is the best and I herd edelbrock don't have as many casting problems these days.
Old Jun 14, 2015 | 04:21 PM
cadmaniac's Avatar
cadmaniac
i took a chance on some heads from Skip White on E-bay. They work ok, $750. Not sure if you could benefit from better heads if you don't have exhaust, headers, cam and intake/plenum upgrades plus a tune though. Then your looking at gears possibly and a stall converter if an automatic.
You can also find replacements all over the place, as I already mentioned in the for sale section, I have a set......they're easy to find.
All depends on your goals and budget.......
To Cylinder heads!
