Distributor wiring harness
Old Jun 14, 2015 | 12:53 PM
jgadbois's Avatar
jgadbois
8th Gear
Default Distributor wiring harness
I was troubleshooting a miss issue in my 86 (late) and removed the distributor cap. I found the connector that holds this wiring harness from the distributor body broken into small pieces.
Is this harness still available? I have had no luck finding one. Wiring harness connects 3 pins of ICM to 4 pin weatherpack connector.
Old Jun 14, 2015 | 01:45 PM
braeburn22's Avatar
braeburn22
have you tried rock auto
Old Jun 14, 2015 | 03:17 PM
jgadbois's Avatar
jgadbois
8th Gear
First place I checked. Not only can I not find the part, I can’t find any kind of description that shows it exists.
I did find a pigtail with the weatherpack connector but nothing for the ICM connector or the strain relief that bolts to the distributor body.
Old Jun 14, 2015 | 11:50 PM
Cliff Harris's Avatar
Cliff Harris
The brown strain relief is part of the harness, which is not available anywhere (that I know of). It doesn't have to flex, so I just let it hang out:
Old Jun 15, 2015 | 05:16 AM
kenmohr's Avatar
kenmohr
I cut a round grommet and pressed it in. Two years and no problem.
Old Feb 24, 2023 | 02:52 AM
8835th's Avatar
8835th
I'm having the same issues lol. Except mine completely fell apart. Can this effect timing? Sorry to bring back an old post.
Old Feb 24, 2023 | 07:38 AM
johnfin's Avatar
johnfin
You can buy all the wiring for the HEI. https://www.corvetteforum.com/forums...hei-parts.html
Old Feb 24, 2023 | 07:42 AM
Vets-Vet's Avatar
Vets-Vet
It's called the Distributor / capacitor terminal block, just type in your year and make and terminal block and they come up.
https://www.google.com/search?q=1986...t=gws-wiz-serp
To Distributor wiring harness
