Vats problem??????
Old Aug 17, 2002 | 09:58 AM
Bob88Convertible's Avatar
Bob88Convertible
Default Vats problem??????
Son's 87 has an intermittent starting problem, acts like vats but not sure. He has a vats bypass kit, but the wires pulled out of the connector. The two wires coming from the ignition are brown and yellow, the two on the vats connector are red and black, can anyone tell me which one connects to which. Also, what else should he check. Thanks in advance for any help on this.
Bob
Old Aug 17, 2002 | 10:19 AM
Frank Zeman's Avatar
Frank Zeman
Default Re: Vats problem?????? (Bob88Convertible)
From previous posts, check the key (resistor chip may not be making contact), ignition switch, and VATS starter relay. Does anyone know just exactly where the relay is? All my book says is "behind the dashboard".
Old Aug 19, 2002 | 09:54 AM
dlmeyers's Avatar
dlmeyers
Default Re: Vats problem?????? (Frank Zeman)
The Model Year 90 is under the hush panel on the drivers side. Not sure about other years. A Helms manual will have a diagram of the exact location but don't have any other years than a 90. This relay is used in about 5 other locations and is very cheap.
dlmeyers 90 coupe zf6 3speed shocks
Old Aug 19, 2002 | 04:36 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Here it is behind the DIC. It's called the STARTER ENABLE RELAY.
Old Aug 20, 2002 | 09:34 AM
Rich B.'s Avatar
Rich B.
Default Re: Vats problem?????? (Ray Quayle)
Ray -
Is that location good for my '86, too? Good to know where it is...Even if it takes 8 hours to get to it... :rolleyes:
Old Aug 20, 2002 | 02:28 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Default Re: Vats problem?????? (Rich B.)
Ray -
Rich,
Yes it is. It isn't that difficult. The radio/HVAC trim comes right off and like 4 screws for the DIC.
To Vats problem??????
