Electronic Climate control dead.
Old Jun 15, 2015 | 03:56 PM
fast.asleep's Avatar
fast.asleep
Default Electronic Climate control dead.
I noticed it was dead yesterday. It seems like a power issue but what? Any ides would help. (The fuse looks fine)
87 l98
Old Jun 15, 2015 | 04:01 PM
antfarmer2's Avatar
antfarmer2
87 l98
Pull them and clean might just be loose or crudded up. or a bad ground
Old Jun 16, 2015 | 01:00 AM
Cliff Harris's Avatar
Cliff Harris
The A/C fuse is for the compressor.
There are two fuses for the HVAC control head: CTSY/CLK to maintain the settings in memory and the GAGES fuse for the head electronics.
Old Jun 17, 2015 | 09:52 PM
scooter mcfly's Avatar
scooter mcfly
When you say "dead" do you mean it no longer works or the lights and digits do not illuminate? Are you getting anything out of the vents?
Old Jun 17, 2015 | 10:04 PM
fast.asleep
It no longer works and the digits/buttons do not illuminate. Nothing out of the vents either. The radio and everything else work fine. It's like someone unplugged the head unit
Old Jun 17, 2015 | 10:05 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
google or seach forum for removing the hvac moldule and cleaning all the buttons and the board contacts. mine was on the fritz, blinking lights sometims other times black other times good.
i removed the board and cleaned all the gold pins and slightly bent them up to ensure contact. good as new. but search the forum u will find it. easy peazy.
fast.asleep
That would explain why the fuse looks fine. Now to look at the correct fuse
Old Jun 17, 2015 | 10:09 PM
fast.asleep
Thanks. If the fuse checks out that's what I'll be doing next.
Old Jun 17, 2015 | 11:14 PM
scooter mcfly
Try disconnecting the negative terminal on the battery. Then reconnect it and turn the ignition to run, or start the engine. If there's power to the climate control unit it will default to auto and you'll get air blowing out the vents. Also, the radiator fan will turn on. If it doesn't, you'll need to pull the unit and verify power and ground at the connector. Opening the unit to get to the circuit board inside will be pointless if it isn't getting power. Have you tried tapping the face of the unit? If the circuit board pins are loose the lights may blink from tapping on the face. I pretty much did the same as VikingTrader. Bent the terminals up to make contact with the pins on the circuit board. Clean them first. Has been working perfectly since. Try the other things first. Don't tear the unit apart if you don't have to.
Old Jun 18, 2015 | 12:30 AM
fast.asleep
I assumed bending pins would require me to take it apart. Are you referring to the pins on the exterior of the unit that connect to the cable?
(BTW: that's how I first noticed. Not having to turn it off when I reconnected the battery)
Old Jun 18, 2015 | 04:29 AM
scooter mcfly
The circuit board is inside the unit. You'll have to separate the face from the body. This will require breaking it. DON'T PANIC, you only have to break the plastic nibs that hold the face on. There are also two clips on the side. Before you break it open, make sure there is power at the connector. Not sure which terminal supplies power. Probably a red wire with black being ground. Do you have a FSM? If not I imagine you can Google a wire diagram for it. Probably one right here on the forum somewhere.
Old Jun 18, 2015 | 08:27 AM
VikingTrad3r
Oil Producer
Default there is a writeup somewhere in the forum.
has everything u ned.
Old Jun 19, 2015 | 08:17 PM
fast.asleep
ABS and Climate control work now but I ran into a starter/vats issue. I started a new thread for that one: https://www.corvetteforum.com/forums...post1589877872
Old Jun 19, 2015 | 08:37 PM
antfarmer2's Avatar
antfarmer2
Let folks know what the fix was.
Old Jun 19, 2015 | 08:50 PM
fast.asleep
Right, sorry. One step forward and 2 back...
It turns out the wiring was messed up causing the GUAGES fuse to blow. Since I was dealing with 2 cut pink wires that looked identical I wired them the opposite way I did initially and the GUAGES fuse did not blow.
To Electronic Climate control dead.
