Hissing brake pedal?
Old Jun 16, 2015 | 07:27 AM
Pres712's Avatar
Pres712
Default Hissing brake pedal?
Yesterday driving home I pulled up to a stop light and there was a hissing sound (air escaping) coming from the brake pedal. Obviously there is a leak in the power brake system, somewhere. Before I get into it; has anyone had this experience?
Old Jun 16, 2015 | 07:45 AM
antfarmer2's Avatar
antfarmer2
Need a new brake booster or your vacumme line came off or cracked.
Old Jun 16, 2015 | 08:04 AM
WW7's Avatar
WW7
....Yep......WW
Old Jun 16, 2015 | 03:08 PM
Pres712's Avatar
Pres712
Checked under the hood all around the booster, no hissing. Can only hear the air escaping while in the car. Went under the dash and pressed on the brake and the sound is coming from under the dash? If I hold down the pedal the engine will want to stall. So vacuum is leaking from somewhere.
Old Jun 16, 2015 | 03:42 PM
WW7's Avatar
WW7
The back of the booster is under the dash , so don't rule out it being a bad booster yet ..Check the vacuum lines also....WW
Old Jun 16, 2015 | 03:46 PM
antfarmer2's Avatar
antfarmer2
Is the brake harder to push? Pump up the brake with the car off while holding the brake start the car does the pedal go down a bit?
Old Jun 16, 2015 | 04:30 PM
tgurnick's Avatar
tgurnick
It definitely sounds like the brake booster. I had one in my S10 give similar symptoms. The booster might seal up when not bothered, but once you push the brakes the diaphragm could be losing it's seal internally.
Old Jun 17, 2015 | 07:36 AM
Pres712's Avatar
Pres712
It has always gone down a little when starting. The brakes work fine except when it's hissing and then it seems to revert to "hard" brakes-no booster. I'm sure it's a bad seal or something in the rear. I found one on line for $112.00. Not to sure how to replace it.
Old Jun 17, 2015 | 08:06 AM
antfarmer2's Avatar
antfarmer2
Take the old one off first. youtube is your friend. It is suppost to go down a little. Four nuts and a clip.
Old Jun 17, 2015 | 02:04 PM
krackenvette's Avatar
krackenvette
Check the booster closest to exhaust manifold cylinder #7. Thats usually crack central due to heat front exhaust.
Old Jun 17, 2015 | 05:58 PM
gerardvg's Avatar
gerardvg
Have had the same problem, hissing only when pressing the brake pedal.
Did not affect braking assistance much at first, turned out the diaphragm in the booster had torn.
You can get them repaired however most will not want to try, the plastic has hardened with heat over the years and can break when they try to open it.
I got a new one and make sure i do not bleed the brakes the old fashioned way, that extra travel usually does the diaphragm in my experience.
Is a fairly simple straight forward job to replace the booster.
Old Jun 17, 2015 | 09:46 PM
scooter mcfly's Avatar
scooter mcfly
You are in for a treat. You're gonna need lots of extensions for your ratchet. 1/4 inch will be easiest. There just isn't much room under the dash to work. Remove the drivers seat. I would tape either a towel or sheet of plastic to the firewall under the dash so when you drop the nuts, and you will, they won't disappear into the black hole the resides under the steering column. You're gonna be lying on your back trying to hold a flashlight in your teeth while trying to get your socket on the bolt with one hand and working the ratchet with the other. Plan on cussing a lot. Beer is your friend. Before you put yourself through this ordeal, and yes that is what this is, check the check valve on the booster. If it's bad you could save yourself a lot of time, money, and aggravation.
Old Jun 18, 2015 | 07:49 AM
Pres712's Avatar
Pres712
I watched a video on YouTube and I think I will ask my Corvette garage what they will charge. They get $75/hr. Maybe 3 hours? Might be worth it. I'm 6'2" 250 lbs. Could be a squeeze?
Old Jun 18, 2015 | 08:29 AM
antfarmer2's Avatar
antfarmer2
I am the same size just add two inches. Just have everything set up and a little head light will help wish I was closer $225 for a clip and four nuts. use some tape in the socket to hold the nut
Old Jun 18, 2015 | 08:52 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
Have you checked the vacuum operated cruise disengage switch for leaks? It is mounted by the brake light switch, behind the brake pedal, under the hush panel. Remove the panel, start the car, press the brake pedal with your hand and listen. The switch is only activated when you depress the brake pedal. They are plastic and do go bad. It's a fast an easy check before tearing out your booster.
If it leaks, you can hear a hiss when you press the pedal.
Old Jun 18, 2015 | 10:47 AM
krackenvette
Thanks. Love learning new stuff. Now I need to check mine
Old Jun 18, 2015 | 12:51 PM
scooter mcfly
Don't give up so fast. If a mechanic can do it, you can. No special skills required. You'll actually be pretty comfortable down there. And the convertible makes it easier to get in and out. The hardest part will be finding a combination of extensions that will work. Cover the studs the seat attaches to with a towel so they don't dig in. A helper would be nice for when you drop something. And lots of beer. And music. You'll be fine.
To Hissing brake pedal?
Old Jun 18, 2015 | 02:31 PM
antfarmer2's Avatar
antfarmer2
The hardest part will be trying to drink beer under there LMAO
Old Jun 18, 2015 | 03:06 PM
scooter mcfly
Only if you haven't stocked up on vacuum hose! 4 or 5 ft should do.
Old Jun 18, 2015 | 04:01 PM
antfarmer2's Avatar
antfarmer2
