Servicing A/C that has R12
Old Jun 22, 2015 | 03:20 PM
colter's Avatar
colter
Originally Posted by desertmike1
This makes it a better reason to dissemble the 10PA, and drain out the old Mineral oil, the new replacement seals will be compatible with R134/Pag oil.. I had mine apart several years ago, and it is a really easy job..
What can you use to clean the inside of the compressor while you have it apart?
I was thinking of spraying it clean inside like when you clean a throttle body or something. But don't want to use unsafe products that would damage the compressor or the metal/plates inside.
Probably will pull the orifice first to make sure it's not covered in black metallic slim.
Old Jun 22, 2015 | 11:48 PM
Cliff Harris's Avatar
Cliff Harris
Originally Posted by colter
If I stick with R12, do I also have to replace the accumulator and orifice?
The accumulator has desiccant in it that is supposed to absorb any moisture that gets into the system. It's a good idea to replace the accumulator any time the system is opened.
And anyone know the system capacity for freon?
That depends on the year and I don't know the capacity for your car.
Old Jun 22, 2015 | 11:59 PM
Cliff Harris
I've been wondering the same thing. I have a Denso compressor in pieces on my bench. I've tried brake parts cleaner, carb cleaner, denatured alcohol and mineral spirits. None of them dissolves the mineral oil.
The only thing I've found that works is 409 but I'm afraid the parts will rust if I use that. I don't know what kind of metal the various parts are made of. The pistons look polished and a magnet won't stick to them so they could be aluminum or stainless steel.
I read somewhere that you shouldn't use anything that is chlorinated.
Old Jun 23, 2015 | 01:43 AM
colter's Avatar
colter
Only thing I can find is they say when flushing the A/C to NOT flush the compressor. But can't find anything about if you can use something to clean the inside of the compressor if you have it apart. I watched a video where the guy replacing seals on a 10PA said you have to wear gloves, as the oils on your fingers I guess can damage the plates inside it.
I guess at least do a dray wipe down if there is crap inside it. Then when together fill with oil. Turn it over for a while, then dump the oil and repeat.
Old Jun 23, 2015 | 12:38 PM
desertmike1's Avatar
desertmike1
you don't have to chemically clean the inside of the compressor, drain it well, and wipe it down.. The only time it is critical to wear latex glove's is when you handle the "Shaft Seal" they are sometimes designed with a "Carbon" wear surface, and are ground perfectly flat for a good sealing surface. The new ester based lubricants act like a degreaser and can easily handle small amounts of mineral oil. Now your Accumulator needs to be replaced if you switch over to 134, it was designed for an R12 system and is not compatible with R134.
The 5 case bolts require a new copper gasket that comes in your seal kit, and need to be torqued to the proper value.. this I don't remember.
Old Jun 23, 2015 | 07:27 PM
colter's Avatar
colter
Yeah, I learned of the need to replace the accumulator and orifice tube. I'll probably try to stick with R12, as I believe R134 puts more strain on the compressor which can cause it to go bad quickly if it's worn. I'll probably see about putting a dye in first to see if there are any other places that are leaking like the condensor. I believe the evaporator had already been replaced as it doesn't have the foam piece on it like I believe the OEM one had.
Old Jun 23, 2015 | 07:47 PM
antfarmer2's Avatar
antfarmer2
You can buy a sniffer for $20.
Old Jun 23, 2015 | 07:52 PM
crowz's Avatar
crowz
Another day of 38 degrees from the vents and 95 degrees outside cruising down the road with 134a in my r12 system with nothing done but the conversion kit.
$39.95 spent and zero problems.
As for ones done long term.
1984 blazer - 767,000 miles, 6 engines, original transmission. Converted to R134a around 140k miles. Still blows snowballs.
1985 trans am - Over 300k miles. Converted to 134a with the kit around 110k miles. Still works.
1978 Monte Carlo - Converted around 180k miles. Had 290k or so on it when I sold it and was still ice cold.
Ive converted literally 100's of cars and with no major failures from the conversion with just the conversion kit. I still top off cars for people all the time but the ones "leaking" were doing that before the conversion and the owners are to cheap to fix the system right. At least now they are just venting safe 134a in place of the r12 is one way of looking at it.
Old Jun 25, 2015 | 11:32 PM
colter's Avatar
colter
Anyone had problems converting to R134? i.e. compressor failures?
It would be the best time to convert though since I'd be replacing the seals in the compressor and have to fix the schrader valve leak.
Could install the R134 fittings on the schrader valve, flush out the lines and condenser and evaporator and replace all of the orings and put in a new orifice and accumulator.
I believe you use ester oil for conversions, which I believe is 8oz you put in a flushed system.
I believe the A/C hoses used in 89 are okay to use with R134? I recall reading the type of hoses used in earlier years won't work with R134 because they are more porous. I forget the year though.
Old Jun 26, 2015 | 09:51 AM
357L98's Avatar
357L98
I put R134 in my 85 years ago, and have had no problems with it. I used the original hoses, and ester oil. It gets really hot here in the summer, and it keeps me cool.
Old Jun 26, 2015 | 10:16 AM
colter's Avatar
colter
Did you put in a different orifice? I've read of GM R12 to R134 conversions where people change the orifice to a blue Ford orifice instead of the GM white orifice.
Also read of people changing the low pressure switch from an R12 (25 PSI) switch to an R134 (22 PSI) switch.
This is an interesting readings:
http://www.misterpeachy.com/VetteStu..._to_Denso.html
http://tech.corvettecentral.com/2008...4-ac-retrofit/
Old Jun 26, 2015 | 10:51 AM
357L98's Avatar
357L98
[QUOTE=colter;1589921544]Did you put in a different orifice? I've read of GM R12 to R134 conversions where people change the orifice to a blue Ford orifice instead of the GM white orifice.
I used the standard GM replacement orifice from the parts store when I replaced the compressor. I have heard of the Ford orifice swap, but never tried it. Didn't feel like having to go back in there if it didn't work right.
I left the original low pressure switch on the accumulator. I have seen the aftermarket ones with the R134 calibration, but the R12 switches have the same adjustment screw between the terminals, so they can be recalibrated for 134 also. It is possible the R134 switch could give better cooling.
My plan was to leave everything stock, see how it worked, and make changes or adjustments if needed. As it turned out, it seemed to work fine, so I left everything alone. That was 5 or 6 years ago, and it still works.
Old Jun 26, 2015 | 11:19 AM
  #33
colter's Avatar
colter
I'll probably just look at converting it to R134 since I'll be tearing it apart anyways. Hopefully the compressor is still good as it's probably be running on low oil. Mine is 89, so I think the hoses are good for R134 as I think they went to barrier hoses in 88.
I'll probably tear it apart to flush it out, put in new orings, dryer, and orifice tube, add oil, and change to R134 fittings. And then take it to a shop to put a vacuum on it and add the R134.
Old Jun 26, 2015 | 11:31 AM
  #34
357L98's Avatar
357L98
That should work. But if you're able to do all that you might as well get a harbor freight vacuum pump for $99 and some Big Lots R134 for $7 a can and charge it yourself. Probably still cost less than paying a shop.
Old Jun 26, 2015 | 11:45 AM
  #35
colter's Avatar
colter
The problem is knowing how to charge it. Been doing some reading on the change over process, but they don't really go into depth in how to charge it up where you don't over charge it or under charge it. Still doing some reading, so may be able to understand it. Was thinking a shop would know how to properly charge it. I know you are supposed to do something like 80% of the R12 charge.
Old Jun 26, 2015 | 11:49 AM
  #36
357L98's Avatar
357L98
You can do it. Pull a vacuum, dump a whole can in upside down (liquid), start the engine and dump another can in and see how it cools and check the pressure. Usually takes about half another can to get the high side up to around 250 and it should be good.
Old Jun 26, 2015 | 12:53 PM
  #37
colter's Avatar
colter
Is it 8 ounces of ester oil when converting to R134?
To Servicing A/C that has R12
Old Jun 26, 2015 | 01:00 PM
  #38
357L98's Avatar
357L98
Yes, put 2oz each in the accumulator, evaporator, condenser, and compressor.
Old Jul 26, 2015 | 07:50 PM
  #39
colter's Avatar
colter
I'll be getting a tank of R12 and R12 manifold gauges. Looks like you can't really find adapters for the gauges to connect to the 3/8 and 7/16 A/C ports.
May just get R134 manifold adapters, and put R134 quick connect adapters on the A/C lines.
Old Jul 26, 2015 | 08:10 PM
  #40
antfarmer2's Avatar
antfarmer2
Look on ebay and buy the valve tool remover kit that you remove the valve stems without looseing freon it come with all the connectors and very handy. Mine has paid for itself many times over. I never charge but they are so happy they tip.
