89 runs rough when cold, fine when warm
Old Jun 19, 2015 | 04:00 AM
cv67's Avatar
cv67
St. Jude Donor '05
Default 89 runs rough when cold, fine when warm
No visible codes......
Guess is the CTS, anyone else?
Old Jun 19, 2015 | 07:27 AM
ex-x-fire's Avatar
ex-x-fire
It could have dirty injectors, a cold engine needs more fuel. So if the injectors are dirty, they may be allowing the engine to run lean. The ecm might not set a code for this.
Old Jun 19, 2015 | 10:19 AM
volkswagens-for-life's Avatar
At what temp does the car start to run properly? There is closed loop and open loop mapping which ties into what ex-x-fire said.
Old Jun 19, 2015 | 12:15 PM
cv67's Avatar
cv67
St. Jude Donor '05
Dont know the exact temp looking at the car tomorrow
Its a TA but TPI same as a Vette
It sat for a yr in storage and started doing it when he pulled it out
When my 89 Vettes injectors went bad it was slightly rough cold and real bad hot (closed loop).
Dont want to have to pull a TPI apart in this heat, have no garage now.
To pay someone it would take over a grand, hoping for a quick fix, its a pretty clean ride.
Old Jun 19, 2015 | 12:23 PM
crowz's Avatar
crowz
Usually on the trans am I had the rough cold smooth warm was the coolant temp sensor being bad.
The computer and the gauge have separate sensors.
To 89 runs rough when cold, fine when warm
