I did it again, here is a video on how to adjust the trans throttle valve cable on a 1992-1993 C4. The adjustment is done at the ASR actuator (Acceleration Slip Regulation). Listen to what the guy in the video says, if you don't make the proper adjustment you possibly could ruin your automatic transmission clutch packs due to slippage!! On the other hand you could get that baby to shift awesome! Enjoy watching, comment, share and all that good stuff. Take it easy - Ozz
Nice. Great instructional. I went the long route, and after putting transmission in I had pan off and verified tv cable was adjusted according to where it should be next to plunger. I think this method is better.. Mine doesnt down shift as easy. I will go do this and see if it changes. I hope it does.
It did. It confirmed that the OCD way I did it was slot on..lol. wish i had this when I did the transmission the last three times. Drag racing and 396 plays hell on 4L60's... yes it has been built pretty damn good this last time too..
