infrequent lagging throttle response
Old Jun 19, 2015 | 03:47 PM
Barchetta's Avatar
Barchetta
Default infrequent lagging throttle response
'94 coupe, 45K miles. I notice infrequently when I step on the throttle the car lags and kind of sputters, for a few moments and then it's fine. It seems to only happen right after car has been started and first driven. Work so far that has been done in the last year includes:
-New vented opispark
-New plugs, wires
-New injectors
-New radiator
-New themostat
-New coolant temperature sensor
-New hoses where needed
I also did a block/headgasket test, with the test kit rented from autozone, that tests for exhaust gasses in the coolant and results were negative.
Other than that small, occasional issue the car runs great.
Any ideas?
Old Jun 19, 2015 | 03:57 PM
antfarmer2's Avatar
antfarmer2
-New plugs, wires
-New injectors
-New radiator
-New themostat
Any ideas?
Had the same thing on my 94 no codes put new o2's in the front and hold on never ran better. I changed the knock sensors at the same time to do a proper flush
Old Jun 20, 2015 | 07:39 AM
67Olds442x2's Avatar
67Olds442x2
My 94' did the same thing before my rebuild. I replaced all sensors, switches, opti, O2, coil, everything during my rebuild. Complete engine rebuild and was I surprised when it still sputtered and lagged behind, not as bad but still there. Before I could floor the pedal and the car would buck, sputter, and I could feel and hear popping under the car. Now I've been focused on the TPS because the voltage is low during readouts, changed two and still low. Now its looking at all the wires. My car has 108K on it and before I would let it warm up longer, mine did it after start up also. Yours is low miles but looks like you had to change out some parts already. I'd check Throttle position sensor, MAP sensor, and fuel pressure. The only thing on mine I didn't change is the fuel pump, had it out but didn't change it. Good luck.
Old Jun 20, 2015 | 09:04 AM
WW7's Avatar
WW7
The first thing I would check would be the "Throttle Position Sensor"...You can check this yourself with a Multimeter or a scanner..WW
Old Jun 20, 2015 | 10:19 AM
Barchetta's Avatar
Barchetta
If it is the TPS wouldn't it be happening all the time? Why only at start up?
I was also thinking it could be a bad or clogged or failing fuel pump, but then why only after startup?
Old Jun 20, 2015 | 10:32 AM
Barchetta's Avatar
Barchetta
...btw ... the lagging throttle response, sputtering and poping (like a backfire) was hapening really bad and more frequently before the injectors, plugs, wires were relaced. Since then it is very infrequent and only right after starting up and only happens once and then it runs fine. To me it seems like it would be more fuel related like a sensor or component that delivers, regulates or measures air and/or fuel, rather than an electrical issue. All the wiring appears to be in good condition. However, I could be wong as it's only an assumption.
Old Jun 20, 2015 | 11:18 AM
antfarmer2's Avatar
antfarmer2
that's what o2's do I used bosch are you going to do it?
Old Jun 20, 2015 | 11:30 AM
crowz's Avatar
crowz
Not really. TPS can either die outright, have dead zones all the time or act up based on temperature. The last one I changed in mine worked fine cold but went nuts the warmer the car got. Even to the point before it went out of having nothing from 1/2 pedals worth onward when the motor was warmed up.
Old Jun 20, 2015 | 11:37 AM
Barchetta's Avatar
Barchetta
It could't hurt. the parts aren't that expensive. I'm assuming if the O2's are failing it could happen just at startup untill the system compensates? I was reading up on symptoms and it was suggested that O2's should be looked at as maintenance items replaced at 50k miles.
Are the Bosch to OE specs?
Old Jun 20, 2015 | 12:07 PM
antfarmer2's Avatar
antfarmer2
Once the loop change they come into play. Bosch is what I put in. Get the wrench set from Orielys for $20 deposit or buy for $25 use the short one.
Barchetta's Avatar
Barchetta
When was your lagging throttle happening? Was it after cruising speed or in lower gears?
Mine being an auto I notice when in last gear, usually at cruising speed, throttle response and acelleration is slow unless I downshift into D or step on throttle hard, but I understand that is just normal torque converter operation.
Old Jun 20, 2015 | 12:46 PM
crowz's Avatar
crowz
When this last one went it was at cruising speed.
But it sounds more like your car needs a tuneup than anything else to be honest. I was just pointing out that the tps can be erratic and not a dead completely thing.
Id start with airfilter (my 86 would do exactly where your referring to when it got dirty), plugs, and o2 sensors. To me that's a tune up.
Old Jun 20, 2015 | 01:15 PM
Barchetta's Avatar
Barchetta
Btw... I usually let the car warm up to about 100df before I drive. It happens shortly after that. Also after it has been driven and sitting off for a while, and engine still warm, then I start up again and drive it hapens (as mentioned before) once then it is fine. I'm almost sure it's in closed loop when it happens.
Old Jun 20, 2015 | 02:20 PM
67Olds442x2
Don't know if you have a manual or not. Scan 1 bottom right para and scan2 left side, Describes fuel metering a little. Scan 3 trouble shooting steps. Just a guide, for me I have to know how a system works first. Check for any codes you may have.
To infrequent lagging throttle response
