belt Q:
Old Jun 20, 2015 | 12:52 AM
Linda_C's Avatar
Linda_C
6th Gear
Default belt Q:
My car needs a tune up and the pro charger rebuilt.. can my car run without the SC? i cant see in my engine if its one belt doing everything or the SC is on its own belt? anyone know?
LT1 v8
Old Jun 20, 2015 | 08:41 AM
WW7's Avatar
WW7
First off, your in the wrong forum, you need to be in the "Forced Induction" forum... If you want an accurate answer to this question, you may be better off calling Pro Charger directly...Then you can be sure the answer is correct..........WW
PROCHARGER PHONE # 913-338-2886
Old Jun 20, 2015 | 09:04 AM
c4cruiser's Avatar
c4cruiser
There is a pic on the ProCharger website that shows a Corvette LT1 engine with their supercharger and it appears that the supercharger is driven by the engine serp belt. I would expect that the belt used for that application is much longer than a stock belt so the problem would be running the car without the supercharger possibly creating a bigger problem with the custom tune. Also finding a smaller belt to drive the accessories like the PS pump, alternator, A/C, and the idler pulley and tensioner
You do need to contact ProCharger to see what the turnaround time will be for a rebuild. I would suggest that the car not be driven until the work is done.
Old Jun 20, 2015 | 09:17 AM
WW7's Avatar
WW7
c4cruiser,
I started to mention the tune problem in my post above, but changed my mind......It does make sense that the tune would change if the procharger was bypassed, this could damage the engine if the car was run with the tune very far off.....WW..
To belt Q:
