Gas filter replacement: mission completed
Old Jun 22, 2015 | 07:34 PM
Christi@n's Avatar
Christi@n
Default Gas filter replacement: mission completed
Finally i've got it, was not so difficult, just need to disconnect supply and return fuel hoses at the gas filler neck (as many guys had suggested me)
Then disconnect lines before filter, discharge gas in a can, pull up the filter trought engine bay, replace it, o rings, and the job is done
Replaced mine that was maximum 65000 mi old, bad conditions, a pleat is broken too...
Definetly fixed hesitations at low rpm
Old Jun 22, 2015 | 07:43 PM
Christi@n's Avatar
Christi@n
If it has 65000 is 20 years old filter, don't know, since that i've find out a 16mm hex nut of fuel line stripped a little, there's possibility that filter was not the OEM filter......
However seems was not in good conditions, IMO.....
The most alarming things is the broke pleat, no filtration I can report...
Old Jun 22, 2015 | 08:35 PM
Joe C's Avatar
Joe C
Old Jun 23, 2015 | 08:12 PM
Ford1776's Avatar
Ford1776
Glad you got it replaced
Old Jun 24, 2015 | 05:36 AM
Christi@n's Avatar
Christi@n
Anyone know, a little loctite threadlocker should be put on line??
Old Jun 24, 2015 | 08:01 AM
antfarmer2's Avatar
antfarmer2
I never have . good job.
To Gas filter replacement: mission completed
