I've searched..... and it seems most people drop the exhaust and leave the center beam to remove the drives shaft. I'm wondering if anyone has had any success in removing the DS without dropping the exhaust. My car is an 84' and the exhaust bolts look sketchy. I did cut out the cat and ran a straight pipe last year..... shoudl have done the ujoints then
Everyone knows that if you are good enough you can take your brake pads off without taking off your rims.....
I'm more interested in the DS. I thought I read somewhere here that you can angle / slide it in a such a way and eliminate the need to remove the exhaust.
