TPIS Headers Round Port
Old Jun 27, 2015 | 09:37 PM
rrt898's Avatar
rrt898
Default TPIS Headers Round Port
I have a 1986 coupe with iron heads. I just received my TPIS LT headers. The headers have a round port and the heads have a rectangular port. I am assuming TPIS knows what they are doing. Can I bolt the headers to my iron heads? Which gasket would I use? I waited almost four months for the headers. I hope I can use them.
thanks for the help......
Old Jun 27, 2015 | 09:58 PM
JackDidley's Avatar
JackDidley
They will sswork, They should have come with Felpro 1404 gaskets.
Old Jun 27, 2015 | 11:33 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Round ports Ok. Well u want a larger port on the header side as it helps resist the reflected exh pulse wave - reduces exh reversion back into the cyl. If your header port is larger than the head port your doing well. If head port larger than header port u lose the advantage of reduced reversion into cyl. Hard to find round port headers for L98 and LT1 as most mfrs build a D port header to match the D port head. Must be a big secret the D port head is just to turn the exh out of the head and a D port does nothing for the exh flow once its straightened into the header pipe.
BTW i like TPIS products and will be surprised if not correct but please post what u find - it helps us all. U could call TPIS for an answer.
Old Jun 28, 2015 | 01:13 PM
383vett's Avatar
383vett
With the numerous headers I have run, sometimes the ports on the headers impinge on the exhaust ports on the heads, especially in the corners. A die grinder takes care of that quickly. Make sure you don't grind through the tubes.
To TPIS Headers Round Port
