Oil Capicity on 93 LT1
Old Aug 18, 2002 | 01:44 PM
a0523's Avatar
a0523
Default Oil Capicity on 93 LT1
The owners manual says the 93 LT1 holds 4.5 qts with a filter. However, when I put 4.5 qts in the engine it does not fill all the way to the top of the full line on the dip stick. Is that normal, or should I fill until it reaches the top of the fill line?
Thanks.
Old Aug 18, 2002 | 02:52 PM
REW89's Avatar
REW89
Default Re: Oil Capicity on 93 LT1 (a0523)
Mine is a L98, but is that 4.5 quarts WITH or WITHOUT a filter change? My guess it is 4.5 quarts if you do not change the filter (.5 quarts stays in the old filter) and it is 5 quarts if you change the filter; but checkyour owners manual again for the with/without clarification. Don't rely totally on this advice.
Bob White
Old Aug 18, 2002 | 03:02 PM
STL94LT1's Avatar
STL94LT1
The owners manual for my 94 calls for 4.5 qts. oil and filter.
Old Aug 18, 2002 | 07:56 PM
Lone Ranger's Avatar
Lone Ranger
Most of us put in 5 qts to get to the line on the dipstick. When dealer did oil change (ONLY because they had to drain oil to fix a main seal leak under GMPP warranty..would never have dealer do an oil change otherwise-- too easy to do myself) they also put in 5qts.
So 5 quarts it is!
To Oil Capicity on 93 LT1
