valve covers
Old Jun 28, 2015 | 05:18 PM
jseremba's Avatar
jseremba
Default valve covers
Hello everybody
I own a 1984 4 plus 3. I just put a camshaft and went with roller rockers. The valve covers do not work with these rocker arms. The tab inside the cover touches the rocker. Does anyone have a suggestion as to which valve covers I should use. I am assuming that I need covers with crankcase breathers, correct. Thank you
Old Jun 28, 2015 | 05:35 PM
c4cruiser's Avatar
c4cruiser
Use a grinder to remove the tabs. The stock valve covers will work fine after that.
Old Jun 28, 2015 | 05:52 PM
John A. Marker's Avatar
John A. Marker
Use a grinder or a Dremel with a cut off wheel to remove the drip tabs. Don't try to bend and break them off....you will break a hole in the cover and they will be useless at this point
Old Jun 28, 2015 | 07:27 PM
jseremba's Avatar
jseremba
I was actually wondering if grinding the tabs is a viable option. Thank you
Old Jun 28, 2015 | 07:32 PM
John A. Marker
Yes, grind them off as close to flush with the cover as you can or cut them off. I did that with my stock covers for my 85 running 1.5 & 1.6 RR. When I built the ZZ4 I used 1.6 rollers with a .534 lift on the exhaust. I used a little taller gasket and the covers worked fine.
Old Jun 28, 2015 | 07:38 PM
jseremba's Avatar
jseremba
Well the dremel, the greatest tool known to man, it is.
I was thinking of tuning the lifters by rotating the cam. My question is Does anyone know how far the spring compresses when the lobe is up. Thank you.
To valve covers
