C5 Brake Upgade?
Old Aug 18, 2002 | 11:34 PM
95Redsled's Avatar
95Redsled
Default C5 Brake Upgade?
Is there much improvement in the standard C5 calipers and rotors over my current 13"in system on my 95? How much are the adapter kits required for this upgrade and how big a PIA is it to install? Thanks :chevy
Old Aug 18, 2002 | 11:54 PM
STL94LT1's Avatar
STL94LT1
Default Re: C5 Brake Upgade? (95Redsled)
Check out Jeff Kopp's web site there is a list of all the parts needed for the conversion. The adapter brackets run around $280.
superchevyperformance.com
Old Aug 18, 2002 | 11:57 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Default Re: C5 Brake Upgade? (STL94LT1)
Its eazy to install. I just did it this weekend...
Old Aug 19, 2002 | 04:32 AM
DON M's Avatar
DON M
IMHO, it is the best bang for the buck brake upgrade. Unless you see alot of track time, and then the prices begin to escalate rapidly.
Old Aug 19, 2002 | 05:01 AM
Hawaii89vette's Avatar
Hawaii89vette
Default Re: C5 Brake Upgade? (DON M)
When you install the C5 brakes in the front, do we need to install that brake bias spring in the master cylinder to even out the front brakes with the stock rears?
-Tim (mariah@hawaii.rr.com)
Old Aug 19, 2002 | 05:36 AM
DON M's Avatar
DON M
Default Re: C5 Brake Upgade? (Hawaii89vette)
When you install the C5 brakes in the front, do we need to install that brake bias spring in the master cylinder to even out the front brakes with the stock rears? -Tim (mariah@hawaii.rr.com)
I haven't done mine yet and the thing still stops like a race car.
It feels like it will make quite a difference. The car stops a lot better, but I can tell that the bias is way off. It was noticeable stock, and when I went with the 315 tires on the back it got worse. The C-5 fronts make it really obvious.
I am going to do the rear brakes with drilled and slotted stock sized rotors and ceramic pads, I will do the Bias spring at that time.
To C5 Brake Upgade?
