autocross set up
Old Jul 6, 2015 | 10:08 AM
racerwannabe's Avatar
racerwannabe
St. Jude Donor '06
Default autocross set up
ran the '96 grandsport at the autocross this weekend..need advice on shocks,the bilsteins on the car are WAY to stiff..what is a good non adjustable shock that still lets you drive without jaring your teeth out??
Old Jul 6, 2015 | 10:33 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Stiff is what you want for autoxing, helps keep the rubber on the black top.
Old Jul 6, 2015 | 01:17 PM
c4cruiser's Avatar
c4cruiser
You may want to increase the sway bar size; the front OEM bar for the GS is a tubular 26mm bar and the rear is either a 24mm solid (FE1 suspension) or 26mm solid bar (Z51 suspension).
There were two Bilstein shock types for the GS. The FE1 shocks were fairly soft and there was a stiffer Z51-specific Bilstein shock.
Alignment and tire pressure will be factors in autocross performance.
Old Jul 6, 2015 | 04:10 PM
racerwannabe
St. Jude Donor '06
thank you I believe the z-51 schock will be much better.these are some I had many years ago and thought hey would work,no shock movement to speak of,car just bounced..I'll look into those,
Johnny
Old Jul 7, 2015 | 05:02 PM
93Rubie's Avatar
93Rubie
Actually a firmer shock like a Koni may correct the issue. WHen I had stock FE1 springs (similar to yours) and FX3 Bilstiens the wheels would actually come off the ground during bumpy parts of the course.
FE7 (Z07 springs and bars) plus the Koni Yellows fixed this. Car handles WAY WAY better now. If you time to notice the bumps during an auto-x your not going fast enough!
To autocross set up
