Code 42
Old Aug 19, 2002 | 12:21 AM
Silver99's Avatar
Silver99
Default Code 42
I am looking for some advice on what to do for a code 42. I am intermittently getting a Code 42 that clears whenever I turn off the ignition and re-start. According to the manual a code 42 indicates a problem with the Electronic Spark Control, which I assume is the module inside the distributor. Any advice or suggestions are appreciated.
Old Aug 19, 2002 | 01:29 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Code 42 (CrossfireVette)
If the corssfire is similar to TPI, assure that the set timing connector is secure as it will cause code 42 if open for example to set base timing.
Old Aug 19, 2002 | 01:37 AM
Silver99's Avatar
Silver99
Where is the "Set Timing" connector?
To Code 42
