*IMPORTANT* Coolant problem or not?
Old Aug 19, 2002 | 01:17 AM
Black96Corvette's Avatar
Black96Corvette
Default *IMPORTANT* Coolant problem or not?
I was driving my car for about an hour tonight and it was about 85-90 degrees outside. I floored it about 10 times or so to get that "I'm fast feeling ;)" I noticed I couldn't break the tires loose tonight for some odd reason so when I got home I popped the hood to see if anything was odd. I noticed (LT1 motor) that the (pipes, or coolant hoses/lines) dont know what you call them, were SWEATING or LEAKING. I noticed water or was it COOLANT dripping from the pipes/lines. I didn't want to touch them because of the nice warning GM left on the COOLANT box. Is this normal for them to drip like that, or is something seriosly wrong? I dont want to get the opti wet, I hope someone can help.
Old Aug 19, 2002 | 01:47 AM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Re: *IMPORTANT* Coolant problem or not? (Black96Corvette)
Sounds like your AC lines were condensating, normal if you were running AC :cheers:
Old Aug 19, 2002 | 01:54 PM
vader86's Avatar
vader86
mightve just been your AC lines, you sure it was coolant hoses? because coolant hoses shouldnt be leaking
To *IMPORTANT* Coolant problem or not?
