Yet Another TPS Query...is my voltage enough?
Old Aug 19, 2002 | 03:27 AM
TIMSPEED's Avatar
TIMSPEED
Default Yet Another TPS Query...is my voltage enough?
Ok, here's the specs
Idle - .60volts
WOT - 4.45volts
Will this be enough volts to kick the computer into P/E? What's most people's read at WOT? Jim(65Z01) says it should be 4.60+...but I CAN NOT get it to get that high. Any thoughts?
Old Aug 19, 2002 | 03:42 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: Yet Another TPS Query...is my voltage enough? (TIMSPEED)
3.5 volts is enough to enable PE mode on a stock chip.
Old Aug 19, 2002 | 03:56 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: Yet Another TPS Query...is my voltage enough? (Marcho Polo)
aww..ok, cool. Just checking to see if maybe it wasn't enabling P/E and wasn't giving me enough timing at WOT. Ok, then I made my TPS into "performance" mode with .60volts at idle. heh. Thanks Craig!
Old Aug 19, 2002 | 04:30 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Those voltages will be fine, the higher target would give a little better throttle response though.
To Yet Another TPS Query...is my voltage enough?
