On my 1988, I can't put a square drive 1/2 inch wrench into the square hole on the belt tensioner because it is behind the black disk that is mounted on the water pump pulley. Is there a problem with the tensioner, or what? Thanks.
Thanks! This is my first corvette. What is the frisbee for anyway?
Jim,
I believe the original thought was that the frisbee would absorb the shock of the A/C compressor starting and stopping. My frisbee has been gone for a few years and I've noticed no abnormal movement of the serpentine belt when the compressor engages and it's much easier to access the water pump and the serpentine belt.
