84 with electrical problems
Old Jul 14, 2015 | 09:51 AM
White84C4's Avatar
White84C4
Default 84 with electrical problems
Got this 84 and it runs and drives good. Problem is that it has had mice in the dash and has no power to the fuel pump, fans. The starter and dash are intermittent. 1 out of 30 times turning the key you get the starter to kick. Is there a direction anyone can point me in?
Old Jul 14, 2015 | 09:53 AM
White84C4's Avatar
White84C4
Fans and fuel pump hardwired to battery to work.
Old Jul 15, 2015 | 06:33 PM
1984Z51auto's Avatar
1984Z51auto
If you intend to return the car to the street, you are going to have to pull the dash and wiring harness and go through the harness wire by wire for continuity. The rodents likely chewed it up in multiple places and rodent urine is corrosive also. Not going to be a fun job. If you get real lucky, you might find a good used Cross-Fire harness that you can check out and substitute. Big job!
To 84 with electrical problems
