speratic miss at idle
Old Jul 14, 2015 | 03:32 PM
bob arrowsmith's Avatar
bob arrowsmith
Default speratic miss at idle
Hi folks, I have a 96 a4 lt1 which has a slight miss at idle, car runs fine pulls good and runs fine at steady speed, but when idling at light or any time it sometime will idle good and others time you can feel a slight miss , when ac is on it seems to make it worse, or if it is in neutral it will idle smoother when I put it in drive. also when I blow it out on the freeway and then come to a stop it idles smooth, and after while it will start up again,, im confused, could it be a vacuum leak, bad plugs, or what,,, hope u can help... thanks
Old Jul 14, 2015 | 03:39 PM
John A. Marker's Avatar
John A. Marker
I will assume that there are no error codes. My inclination would be to change the plugs. They recommend changing plugs at about 100,000. If your close or over...plugs are cheap. Go with standard AC Delco.
Old Jul 14, 2015 | 04:40 PM
antfarmer2's Avatar
antfarmer2
Try shooting some cleaner in your TB
Old Jul 15, 2015 | 07:21 PM
luke3's Avatar
luke3
4th Gear
Changing the fuel filter solved that exact problem on my 96. From how it looked i suspect it was still the original one that had been on for 19 years. The nice thing is that it's a cheap part to try. The TB cleaning and plugs as suggested are also cheap and easy maintenance that will do the car good in any case
Old Jul 15, 2015 | 07:58 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I have had these symptoms for years and have yet to find the cure. Replaced everythinf that was mentioned to no avail.
Old Jul 15, 2015 | 09:51 PM
bob arrowsmith
Thanks for the tips,,, plugs have been replace with in the last10k miles TB has been cleaned wires have been relaced, a friend of mine is adamate the the gas hear in so cal is the problem. Sooo i will replace the plugs since they were in the car when i got it just as a precaution and will let ya know,,,,
Old Jul 16, 2015 | 11:37 PM
1993C4LT1's Avatar
1993C4LT1
kimmer, I know your car is a 92. 92 and 93 C4 LT1 are batch fire. From what I read, they won't idle as smooth as the 94-96. With that said, I changed my fuel injectors a while back(2 were leaking), and my idle improved a good bit.
Old Jul 16, 2015 | 11:56 PM
kimmer's Avatar
kimmer
That's the one thing I have not done , could probably use a new set. Kind of gotten use to it sounding like it has a cam.
Old Jul 17, 2015 | 07:20 PM
ATEEZ's Avatar
ATEEZ
Look at vacuum check valve thingy by right side fuel rail...fixed like perfect for me for 4 bucks
Old Jul 18, 2015 | 05:17 PM
mrvette's Avatar
mrvette
I had an aftermarket ZZ9 cam from TPIS, Chaska Minn....Marvin Cotrell, it went into my L98 block and lasted about a year, until that symptom showed up, intermittent bad idle, it drove me krazy for years on end, tried everything from cyl heads UP, changed induction, changed all sorts of crap.....but some years ago when gas hit 4 bux I inquired on the net about a stock L98 cam and a friend sent me one from a Camaro.....
when tearing out that POS ZZ9 cam, the 6 of the lobes were all funky looking on the surface, like the cam finish was destroyed.....I pulled the lifters outta their order on the bench one at a time, and examined them closely, no defects noted....under a mag glass and bright light....
so I wanted better MPG, and so it's the same, but the intermittent idle problem went away for some 6 years now.....
it's the CAM, especially any hotrod cam, and for sure if it's the above POS.....
To speratic miss at idle
