To make a long story short, I didn't uplug the fuel pump fuse then run the car until it died. And now the car is right against the wall so it's not an easy option. Might be a really dumb question, but how can I stop fuel from coming out of one of the fuels lines. I've disconnected the one closest to the throttle body and barely any fuel came out. The other line continually spills out gas. What am I missing?
Remove the fuel cap I found that tempature Chanel's causes pressure to build in the tank and would push the fuel out. I just put the cap one very loose.
The easiest way to close off the fuel line is to take a piece of rubber hose, put a bolt in one end, then slip it over the end of the fuel line, then you can tuck it out of the way as in the picture below...Couldn't be any easier and you don't even need a clamp......You could also just run a short piece of rubber hose from one fuel line to the other..You have to be careful , a friend of mine thought he had the fuel stopped , then next morning had about 15 gallons of gas in his garage...This can cause real problems......WW
